Zaino Application -- Please Check My Steps ... ?
Old Dec 6, 2005 | 05:00 PM
jdg345's Avatar
jdg345
Default Zaino Application -- Please Check My Steps ... ?
Okay, I finally went and bought some Zaino. I have a nice little scratch that I can't seem to buff out with anything in the world so I'm going to see if my Dealer can compound it out. Once I get all that done, I want to start Zaino Application ... so, a few questions:
A: If they have to repaint my quarter panel, how long must I wait before applying Zaino, washing the car, etc?
B: Once I can apply, are these the correct steps:
1. Wash with Dawn Dishwashing Detergent
2. Mix Z7 Wash (1 cap / gal) and slick up an area of the car (how large an area?)
3. Clay area
4. Repeat 2+3 until whole car is clayed.
5. Full wash using Z7
6. Mix ZFX w/ Z5
7. Apply Z5
8. <-- How long to wait before next step? -->
9. Mix ZFX with Z2
10. Apply Z2
11. <-- How long to wait again? -->
12. Apply third and final coat of Z2
I suspect this will take all day more than likely ...
Thanks all!
Old Dec 6, 2005 | 06:21 PM
DavesZ#3's Avatar
DavesZ#3
A) Ask the body shop. Only they know what was used, how it was dried, how long it takes to cure, etc.
B2) I do 1' square sections at a time.
B8 & B11) Drying/curing can be anywhere from 30 minutes to an hour or longer. Depends on temperature and humidity. Give it at least an hour.
If you have a dark colored car (SB, DB, BY) then you might consider two coats of Z-5 and one Z-2 to start. It will help hide swirls better. If you have a light colored Z, then you can do the one Z-5 unless it is heavily swirled then do two.
Yes, to do it all right, it will take the better part of a day.
Remember that a little Zaino goes a long way. You are putting it on really really thin. For a newbie, consider yourself good if you only put 3/4 to 1 oz on per layer. You're shooting for 1/2 to 1/3 oz per layer. Putting too much on will be the biggest obstacle to getting it dryed fast.
Did you buy Z-6? If so, you can put it on between the layers of Z-5/Z-2. It makes the Zaino go on a little easier, especially on a virgin surface. It also aids in removing any streaks of left over Z-* from the previous application.
