water seeping into cabin
Old Dec 13, 2005 | 01:01 PM
dchi_t's Avatar
dchi_t
Default water seeping into cabin
hey guys, not sure if this should go under repairing or cleaning section, but since its cleaning related i'll just post it here.
but anyways, about 3 months ago i washed my car and afterwards i had a puddle of water in the passenger's leg area. i was pissed, and i figured i didn't completely roll up my windows..fine..(my fault) i dried it and every since then i didn't wash my car until this past sunday, i double checked all the windows this time because i remembered what happened last time, and they were all the way up. they did that window tucking thing when u close the door (which means its up) then i noticed that there was water in the passenger's leg are again! wtf?
where could water come in from, im sure all the weather seals are good, i checked them, no cracking, no folding..help. thanks
Old Dec 16, 2005 | 08:14 AM
The problem is serious. Water inside the car will rot the carpet and rust the floor. Both are expensive to fix. I recommend that you get the car to a trusted shop now.
Old Dec 16, 2005 | 08:16 AM
cessna's Avatar
cessna
I agree....
Tell them to do a ""leak-down"" Test....
Goodluck!
dchi_t's Avatar
dchi_t
my car is still under warranty, what should i tell the dealer? tell them wash the car then they'll see the water go into the cabin? damn....this car is really starting to **** me off...so much problems!
Old Dec 16, 2005 | 08:43 AM
I can understand why you are angry. Water leaks are difficult to find. It seems logical that water enters at one particular point, then flows DOWN (gravity). But having some experience with boats, water can move along a rail UPHILL and defy logic.
I wish you the best getting this problem fixed.
Old Dec 16, 2005 | 08:46 AM
dchi_t's Avatar
dchi_t
im thinking when they replaced my passenger window motor they didn't calibrate the window tucking correctly and the window doesnt completely tuck under the window frame? but i didnt see any sign of the door panels wet .
and the other thing is i got my motor replaced recently, and is there something they forgot to put back, maybe they forgot a seal from the firewall and when water gets to it, it'll seep through the seal?
Old Dec 24, 2005 | 03:59 PM
D350Z10's Avatar
D350Z10
The leak is coming from your Firewall where you battery wires go into the car, take apart the pannels and you will see a wire boot, pry is spliced .
Old Dec 24, 2005 | 05:00 PM
dchi_t's Avatar
dchi_t
great! thanks, i will check it out tomorrow when the sun comes up!
Old Dec 24, 2005 | 05:09 PM
D350Z10's Avatar
D350Z10
no prob, you just have to **** it with appox.
Old Dec 24, 2005 | 05:24 PM
sandstormrsx's Avatar
sandstormrsx
yea water leaks suck
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
roadmax
Sep 12, 2015 05:55 PM
PureR3d
Sep 10, 2015 06:23 PM
