How to remove clearcoat?
I want to take the clearcoat off the two aluminum trim pieces around the steering wheel. It is starting to peel bad and I want to respray it with new clearcoat. Does anyone have any idea how to remove the clearcoat without scratching the surface underneath?
You can use a Dremel with the 684-01 Cleaning/Polishing Accessory Set.-
http://www.dremel.com/en-us/attachme...=69625&I=66463
I can defineltly do the acetone thing as I can get plenty from the lab I work in, but will it remove the paint underneath (if indeed it is a painted surface and not real aluminum)?
I tried getting new pieces. Performance Nissan and others said they are not available seperate from the steering wheel so I am stuck. How do you know that they are real aluminum? If they are, that would make life much easier.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
