Why not wax your window?
Old Mar 20, 2006 | 11:15 PM
Z_Driver's Avatar
Z_Driver
Master
Originally Posted by CAN0802
It will work fine for a little while, but if you go through rain often (not SoCal), you will find out that if you do not clean the old wax off from time to time, you will end up streaking your windshield from the buildup. RainX ruined a windshield for me, causing what I can only describe as a broken ice flow pattern on the glass at night in the rain. It made it really difficult to see. I eventually had to replace the window.
Oh my god, did you try fine steel wool first? I tried rainX and had to steel wool the glass to get it smooth again after the first year. Otherwise, the wiper would catch and skip it's way across the surface and not allow the blade to turn over. I use crystal guard now. It does not change with the heat of summer. It's glass fiber's harden on the surface and don't change with the hot summer heat.
If I was to use rainX again. I would steel wool the winshield each spring to get that stuff off and apply a new coat come fall. I think that would work best.
Heat is your enemy here .....
Old Mar 20, 2006 | 11:32 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
i dont quite understand what you're saying.. could you explain again? i used rainx for a pretty long time.. and i had no probs whatsoever.. i don't kno what people are saying when they say it develops streaks or watever and .. whatever you said
Old Mar 21, 2006 | 12:23 AM
Z_Driver's Avatar
Z_Driver
Master
What happens is the rainX gets on your wiper blades after a season and seems to yuck them up. So, you need to clean the blades or get new ones after the rainy season and take off the coating that has distorted them with the summertime sun and the coating that is left on the blade/windshield for six plus months. I like a perfectly clear swipe each time in both directions so it upsets me if it doesn't clear properly or squeak doing it. Some cars / blade types don't seem to have this issue. However, I have never been so lucky.
The way I fixed it was to put new blades on and steel wool the windshield after reasearching a fix for it on another car forum. The rainx really screwed up things for me after the first year of use.
Now, I use another product that doesn't distort in the heat. Crystal Guard QG.
It's used for paint protection, however, works great for this as well.
I use it on all of my vehicles and haven't had a problem with this since.
Old Mar 21, 2006 | 01:05 AM
3hree5ive0ero
Retired Admin
ah i c. thanks for clearing that up. so far i've not had that trouble yet so i think i will continue using rainx, at least until i run out of the current stock. i guess i'll watch for wat you've pointed out
Old Mar 21, 2006 | 12:38 PM
Wangatang's Avatar
Wangatang
i've used vanilla moose from Clearkote and water just beads up and flies off the windows. I rarely have to use the wipers now.
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
dcains
Sep 21, 2015 09:28 AM
AP350z223
Sep 8, 2015 04:38 PM
