I suggest everyone get a California Car Duster
Old May 3, 2006 | 08:29 PM
BlueBoxer's Avatar
BlueBoxer
Originally Posted by DavesZ#3
Contrary to popular misconceptions, the Cali Duster is one of the best and safest ways to remove dust, pollen, etc. You don't drag stuff across your paint. It captures and lifts the particles off your paint. I'm not sure how you're going to use a detailing spray and microfiber towel without dragging it across the paint.
If you've ever been to a car show, especially a concours level show, one of the most common tools you'll see in everybody's bag of tricks is the Cali Duster. It didn't get that kind of following by being harmful to a perfect looking paint job.
I use the microfiber towels with liberal amounts of speed shine. I find comfort in having the surface wet before dragging anything across it. I used the duster on my black S13 and was not that impressed. However, I do live in a desert and as a result probably see a substantially more amount of dust build up than some of you are accustomed to. That may explain my bias towards the duster.
Old May 3, 2006 | 09:10 PM
Kabs's Avatar
Kabs
maybe ur car is dusty but here in NJ my car is yellow..... if i dont cover it up over night it will get a tick layer of pollen that you really cant see through the window lol
anyways it works great for a 9 dollar item..... now that its pollen season i highly reccomend it
Old May 4, 2006 | 10:29 AM
leemik's Avatar
leemik
I owned a cali duster once.. I remember it smelled like **** after a while .. dunno if it was the parrafin or what
Old May 4, 2006 | 11:07 AM
zzrobzz's Avatar
zzrobzz
You're not supposed to wipe your **** w/ it!
Old May 4, 2006 | 11:26 AM
leemik's Avatar
leemik
i didn't.. it just smelled like **** for some reason.. so bad that i never kept it in the car.. just in the garage..
Old May 4, 2006 | 11:39 AM
35oZephyR's Avatar
35oZephyR
I've used Cali dusters for almost ten years now. They're awesome if used right.
For guys with black cars, I don't see no reason not to have one in your trunk at all times.
Old May 5, 2006 | 12:45 PM
EdgeOfSanity's Avatar
EdgeOfSanity
i have one, used it once, and will never use it again. I'd rather wash my car the proper way than have swirls.
Old May 5, 2006 | 01:04 PM
zzrobzz's Avatar
zzrobzz
But.....it doesn't cause swirls.
Old May 5, 2006 | 02:24 PM
scottohio03's Avatar
scottohio03
I have used it for 13 years. I have the small one and the larger one. It never has caused a swirl on any of my cars.
Old May 7, 2006 | 11:15 PM
EdgeOfSanity
then why did my recently detailed car have swirls right after i used it? It also left some sort of residue on the car.
Old May 8, 2006 | 02:49 AM
JDMFairlady21's Avatar
JDMFairlady21
how can this thing really cause swirls? you guys mustve been scrubbing the car with it... i mean it says to just lightly pass it through the surface not put any pressure
Old May 8, 2006 | 06:45 AM
Djnaz's Avatar
Djnaz
if you would have read the directions it states to leave it on a peice of newspaper for up to 48hrs before using.... It also states that it will leave a residue the first 2-3 times it used...
Old May 8, 2006 | 07:21 AM
Kabs's Avatar
Kabs
you are not suppose to scrub your paint with this lol
Its suppose to take off loose particles off your paint... Takes off pollen just fine.
Ive had great results so thats why im sharing
Old May 8, 2006 | 07:44 AM
zzrobzz's Avatar
zzrobzz
C'mon, that's ridiculous!
Do you know what swirl marks are? Even if the Cali Duster was made of steel wool, you would have to run it along your car in multiple directions to cause swirls. Otherwise you would just have linear scratches.
Old May 8, 2006 | 11:52 PM
35oZephyR's Avatar
35oZephyR
How the hell would a Cali duster make swirls??
Unless you took it, pressed it against your car and "waxed on waxed off" then proceeded to brush your door panels like a big tooth brush.
In that case, you deserve to have swirls!
All the Cali duster did was take the dust off your car so you could SEE the swirls you made from a previous wash.
Old May 9, 2006 | 12:19 AM
Triji's Avatar
Triji
Although swirls are not caused by circulation motions on the paint surface. Therefore you do not have to "wax on wax off" Swirls are illusions by the refraction of light on the paints surface. Even the straightest of fine scratches will appear circular in the sun.
My take on the Cali Duster is a no - no...
I use Kozak towels where I just lay it on the surface and drag across with no pressure at all...
Check it out....
www.kozak.com
Old May 9, 2006 | 01:58 AM
Kabs's Avatar
Kabs
Check it out....
www.kozak.com
how is that different? You dont put any pressure with the duster either =P I glide it on my paint too... only thing that scratches me car is rocks =\
Old May 9, 2006 | 03:58 AM
  #38
DavesZ#3's Avatar
DavesZ#3
That's not exactly true. I make sure that all washing, drying, waxing and polishing motions are linear. When I do see any swirls, they are all straight line.
The thing about circular swirls is they appear worse because you can see them from just about every angle. Straight line "swirls" appear worse when viewed perpendicular to the direction they're in. As you move to look down the length of a linear swirl, it tends to disappear.
I think your statement needs to be re-worded to say "all swirls are not caused by circular motion".
Also, don't confuse seeing the circular image of the sun in a reflection with a true scratch/swirl that is a circle on the paint.
Old May 9, 2006 | 09:01 AM
  #39
EdgeOfSanity
i guess not seeing as my black car has none unlike the majority of people on this forum.
Old May 9, 2006 | 09:02 AM
  #40
EdgeOfSanity
i have a habit of not reading directions.
