Help, Water Stains
Old May 25, 2006 | 04:41 AM
ML2000's Avatar
ML2000
Default Help, Water Stains
All of my windows have water stains or something else that I can not get off. The stains look like they have gone though a thin layer of glass. I have had this problem since I got the car last Nov. I have used 3 glass cleaners and news paper, White Vinegar (left it on for 10 min and did this 3 times), Cleaner Wax (5 coats), and this stains are still there. I have done a search and have looked at all the threads about this problem, there are other products that have worked for other people on this form. I just don't want to spend more money on products that don't work. I will post pics later today, any help is welcome, thanks.
Old May 25, 2006 | 04:45 AM
ML2000's Avatar
ML2000
Also I have used a Clay bar on this and the stains are still there.
Old May 25, 2006 | 05:07 AM
Malic350's Avatar
Malic350
do u have tint ? is it between the tint and the glass ? I ask cause I have the same problem lol.
Old May 25, 2006 | 05:14 AM
ML2000's Avatar
ML2000
I don't have tint.
Old May 25, 2006 | 05:29 AM
cessna's Avatar
cessna
And your Z is an 06????
What does the dealership have to say about this?
Old May 25, 2006 | 06:23 AM
ML2000's Avatar
ML2000
I have not said anything to the dealership, does the warranty cover glass.
Old May 25, 2006 | 06:29 AM
06blueZ's Avatar
06blueZ
try a razor blade?
Old May 25, 2006 | 08:44 AM
DavesZ#3's Avatar
DavesZ#3
While I can't imagine it being that bad on a relatively new car, but it is possible that the glass has been etched. There is a polishing compound made for glass than you can buy at most glass suppliers (I'm not at home so I can't recall the name). You can use a polisher/buffer like you'd use on your paint to apply this stuff. It will remove the toughest of water marks or etched windows.
Old May 25, 2006 | 09:29 AM
Zincognito's Avatar
Zincognito
interesting.....i had a friend of mine that had the same problem on his old car and he tried EVERYTHING but could never get those water spots off. I wish you luck
Old May 25, 2006 | 09:58 AM
ML2000's Avatar
ML2000
This is what my rear window looks like, thanks for all the help.
Old May 25, 2006 | 10:00 AM
ML2000's Avatar
ML2000
DavesZ#3, was it this stuff.
http://www.amazon.com/gp/product/B00...nce&n=15684181
Old May 25, 2006 | 10:11 AM
VO...'s Avatar
VO...
Administrator
At first I thought the cloud's reflection was the stain. LOL
(Back to topic) Those are some pretty bad water stains. I'm wondering what caused them. Acid rain maybe. Did any chemicals fall on your glass perhaps?
Old May 25, 2006 | 11:09 AM
ML2000's Avatar
ML2000
Vo7848, it could have of been Acid rain, but my paint is fine. The stains are on all the window.
Old May 25, 2006 | 11:12 AM
VO...'s Avatar
VO...
Administrator
True...This might be a far fetched idea, but maybe that CLR cleaner might work. It's the cleaner you use in your bath tub to get rid of calcium, lime, and rust stains. Not too sure how it would work on glass. Might wanna be careful not to get on paint either.
Old May 25, 2006 | 11:37 AM
ML2000's Avatar
ML2000
Thanks for your help Vo7848
Old May 25, 2006 | 01:59 PM
DavesZ#3's Avatar
DavesZ#3
I don't know - the link doesn't work.
The stuff I have is called "Bio-Clean Hard Water Stain Remover". I bought it many years ago. It is the paste, not a liquid. I did a search and found something with the same name and looks like from the same company but it appears to be a liquid.
Old May 25, 2006 | 09:39 PM
Black_Sunshine's Avatar
Black_Sunshine
CLR is fairly caustic, wouldn't want to take the chance of getting it on a painted surface.
Try a 1:1 solution of water and vinegar, maybe stronger if necessary. Soak a cloth and lay i on the glass and let it sit for a while. This should work unless the glass is actually etched, which would be difficult to imagine. If that doesn't work, try some glass polish and a machine polisher as mentioned somewhere above.
Edit: Just saw that you already tried vinegar.
Old May 25, 2006 | 11:29 PM
Ruth's Avatar
Ruth
Do you have the same problem where the wiper blades run?
Old May 27, 2006 | 07:52 PM
ML2000's Avatar
ML2000
Ruth, the problem is also were the wiper blades run. DavesZ#3 sorry about the link, the stuff I am getting is called "One Grand Paste Glass Cleaner". I really hope this stuff work, if I will try "Bio-Clean Hard Water Stain Remover". Thank again everyone.
Old May 28, 2006 | 12:34 AM
Ruth's Avatar
Ruth
Try steel wool,lightly w/windex.Lightly!Hardware store may sell it in gauges,like sandpaper.
