Cleaning upholstery seats
Old Jun 19, 2006 | 12:32 AM
InZpire's Avatar
InZpire
Default Cleaning upholstery seats
Whats a good solution or cleaner to use to clean these seats?
I've got white stain drops from a soda on the middle part of the seat thats between the thighs. Any way to clean this up?
Old Jun 19, 2006 | 09:45 AM
Try a little water and a wet vacuum.
Old Jun 19, 2006 | 11:22 AM
HCJOE's Avatar
HCJOE
Volkswagon sells a cleaner Autoboun (spelling is close....the bottle is in my garage at home). Comes in a plastic container.....solution is yellow.
You mix it in different proportions with water depending on your use......I've taken many a white stain from my black cloth due the soda called Miller Lite!
Old Jun 19, 2006 | 11:43 AM
ANXIOUZ's Avatar
ANXIOUZ
White stain between the thighs.....hmmm.
Just use water. Get the seat a little wet and then dab it dry with paper towels. Works for me anyway. The paper towels draw up the stain.
Old Jun 19, 2006 | 12:09 PM
Z4Zoro's Avatar
Z4Zoro
Depeds on how long the stain has been there. I would use water and a towel if it recently happen. I have used portable carpet cleaner. It uses a warm solution will sucking up the stain.
I used something similar. P & S Rug and Upholstery Shampoo. Works will. You do the same, mix a certain proportion with water and use a sponge or something similar. Maybe use a little simple green with it.
Old Jun 21, 2006 | 08:45 AM
Swiffer's Avatar
Swiffer
I sprayed mine down with scotch guard protectant. You can use this to help protect the cloth from stains. They also sell a cleaner that you can use.
Old Jun 21, 2006 | 09:32 AM
VandyZ's Avatar
VandyZ
One part original Woolite and 10 parts water does great. Make it stronger if needed. Use one towel to rub in and a clean damp (wet is ok too) towel to get it all out. Air dry. Has a nice sent too, better than carpet cleaner IMO.
Old Jun 22, 2006 | 06:59 AM
zzrobzz's Avatar
zzrobzz
If you're serious about it, use this:
jon-doninc.com/catalog/product_info.php?products_id=9125
It works!
3vilbunny
Jul 18, 2017 05:10 PM
_bit
Oct 2, 2015 07:49 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
