Is layering NXT Tech Wax pointless?
Old Oct 1, 2006 | 07:03 AM
nothingremains's Avatar
nothingremains
Default Is layering NXT Tech Wax pointless?
I am about half way through waxing my car now and was wondering if layering works with this wax. It is the type that looks like yogurt.
Heard some people say if you put a second layer on, it only takes off the first layer.
Old Oct 1, 2006 | 08:45 AM
Vamos_Rafael's Avatar
Vamos_Rafael
i layered the paste tech wax ..
dont know if it makes a difference...
but sure shines better and deeper than my previous attempts with Mothers cleaner wax, maguires regular wax, and nxt spray wax
Old Oct 1, 2006 | 09:46 AM
JDMFairlady21's Avatar
JDMFairlady21
i think i read somewhere that after 2 coats it starts to take off the other layer.
NXT Tech Wax is a one-step wax meaning that it cleans and shines. The cleaning property works by essentially removing the old wax (which of course is your current layer of NXT).
Old Oct 1, 2006 | 10:13 PM
mrZeee's Avatar
mrZeee
since it has cleaners you cannot "layer"(somewhat over hyped "concept" IMO) ...but two coats applied 24 hrs apart is the preferred method for maxmium results..helps with producing an even coat...
Old Oct 2, 2006 | 03:09 PM
Mathys's Avatar
Mathys
NXT is suitable for 2 coats, wouldn't do more as it doesn't have any better effect.
Old Nov 30, 2006 | 03:45 PM
350Zenophile's Avatar
350Zenophile
NXT Question:
The bottle says to apply with an applicator pad, but doesn't mention if it should be damp or not. I know this made a big difference in the ease of app. with Zaino and was wondering what y'all recommend.
Old Nov 30, 2006 | 07:31 PM
steelyloc3's Avatar
steelyloc3
Used nxt for the first time the other day. This stuff does not come off easy. I found it worked best with a thin coat. Apply it thick and it is almost impossible to get off. Also, Instead of putting more than one coat of the nxt, I put a couple of coats of carnuba on top of the nxt. worked great for me
Old Dec 3, 2006 | 10:19 AM
Jyoder7's Avatar
Jyoder7
I would stay away from any type of cleaner wax. They contain a polish that removes a thin layer of clearcoat.
Old Dec 3, 2006 | 10:47 AM
mikead_99's Avatar
mikead_99
Nah, NXT has a chemical cleaner only, and extremely mild at that. It takes abrasives to remove CC.
Removing CC with a polish btw, is really the only way to remove swirls, etching, and oxide. Your paint won't meet it's potential without doing this on occassion. If you don't want to take all the effort to polish a one step abrasive cleaner (not NXT) is certainly a safe, though less effective way to remove those defects with periodic use.
Old Dec 10, 2006 | 10:13 PM
litlechina's Avatar
litlechina
usually use some sort of polish (depending on the paint) and the use a wax...but for awesome result wait 12-36 hours in between coats...if u read on autopia.org...this allows the previous layer to harden before the second is applied....this applies to carnuba waxes and such.
You could also apply a synthetic wax and then a carnuba wax for shine and durability
Dr.Paulyy
Jul 29, 2019 07:45 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
ILoveDrifting
Sep 7, 2015 03:15 PM
