what do u use to clean ur rims?
Old Jan 20, 2007 | 05:55 PM
tonychu's Avatar
tonychu
Default what do u use to clean ur rims?
i have a 350z with the forged 19inch g35 rims. i really like the rims on my car but they are super hard to clean. i have to srub like hell and go oin the small spaces to clean it. is there a spray or rim cleaner that cleans the brake dust fast and easy?
Old Jan 20, 2007 | 05:57 PM
Steve-O Z33's Avatar
Steve-O Z33
Meguiar's Hot Rims. Rinse them, spray the cleaner on, let it sit for a few minutes. Wet a soft brush with a handle on it and spray the cleaner on it. Scrub 'em down and rinse it off. Best stuff I've found yet.
Old Jan 20, 2007 | 05:59 PM
zand02max's Avatar
zand02max
Be careful, I have seen many people fukc their rims up with wheels cleaners
Just use good ole fashioned soap/water and elbow grease!\
Change your front pads, you will be amazed!
Old Jan 20, 2007 | 07:01 PM
DavesZ#3's Avatar
DavesZ#3
Soap and water.
Old Jan 20, 2007 | 07:15 PM
Ebony350's Avatar
Ebony350
Any of the quick spray detailers actually work well as spot free finish and shine on wheels. As for the hard to reach places, a high psi pressure washer always blast away build-up, of course you have to be extra careful though.
Old Jan 20, 2007 | 09:52 PM
BMWWW's Avatar
BMWWW
P21S Gel cleaner.
Clings like a ****, no acidic, perfectly swell on all rims that I've come across. That or an APC from Megs.
Good luck!
Old Jan 20, 2007 | 10:00 PM
deezz's Avatar
deezz
Use the same thing. I am very careful though. Only let it sit for about 30-40 seconds or so and then I rinse them off thoroughly.
Old Jan 21, 2007 | 07:24 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
I find it interesting that you guys use soap and water, as the soap in it's self can cause a soapy build up even if well diluted. Different strokes I guess.
I use watered down Hot Rims, or if you are very concerned try using some of your good old car wash like you would on your paint. A nice soft sponge or a very soft tooth brush for awkward bits, and lots and lots of water.
Old Jan 21, 2007 | 07:30 PM
Vegas_Speedster's Avatar
Vegas_Speedster
Wheel Wax! I even used this stuff before I put my wheels on my car.
Old Jan 22, 2007 | 05:47 AM
Thumbs up
Originally Posted by DavesZ#3
Soap and water.
Agree.
Drivers have been cleaning wheels with soap and water for 50 years. There are products in spray cans that sell for $7.99, but why not stick with a safe and trusted method.
Old Jan 22, 2007 | 05:48 AM
Question
Originally Posted by BMWWW
P21S Gel cleaner.
Good luck!
Link please. Thanks.
Old Jan 22, 2007 | 01:40 PM
BMWWW's Avatar
BMWWW
http://autogeek.net/p2wheelclean.html
Get the gel version.. just spray on, and spread if need be. (It has a good sprayer though)
Leave for however long it says to... agitate if need be, and PW the sucker out!
Safe for all finishes, and works better the longer you can leave it be!
Old Jan 22, 2007 | 02:31 PM
BMWWW's Avatar
BMWWW
Agree.
I hear ya, soap and water is all that's needed for well-cared for rims. (Say, washed every other week, where brake dust has yet to bake into the clear)
Unfortunately, some owners just don't care enough for their cars. Neglected wheels with months and months of baked on brake dust ain't going to come out with just soap and water.
I've had a few Mercedes and BMW's with baked on brake-dust, and nothing short of acidic cleaners would clean the rims efficiently. (Especially with those stupidly intricate wheel designs)
There is a fine array of non-acidic cleaners that just make the job so much easier.
Old Jan 22, 2007 | 06:15 PM
Vegas_Speedster
http://www.wheelwax.com Soap and water wont always get your wheels clean. Use wheel wax and then treat your wheels like you treat your paint. Wash them cold, use a carwash solution, blow them dry with a leaf blower and then blot them dry with a white cotton towel. simple.
Old Jan 22, 2007 | 06:25 PM
Thanks. I put it on my to buy list. I use a 50/50 mix of car wash and water in a spray bottle. It works well but not the top inside of the wheel. Will give this a try.
Old Jan 22, 2007 | 06:39 PM
n8vz's Avatar
n8vz
diluted simple green..
Old Jan 23, 2007 | 02:56 AM
BMWWW's Avatar
BMWWW
I would be VERY careful SG.
It has been well documented to dull metals with repetitive use, and you will definitely run the risk of 'whitening' aluminum parts. Exercise caution when using SG, and don't use it too often. There are many safer alternatives as an all-purpose-cleaner. Just hit up autogeek.net, and check out their APC's.. good suggestions are all there!
Good luck!
Old Jan 23, 2007 | 09:40 PM
black06z's Avatar
black06z
I hate the stock 350Z rims. Such a pain to clean and keep clean.
I use Eagle One All Wheel Cleaner (Gray Bottle).
Old Jan 23, 2007 | 11:03 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Haha, they're a whole easier to keep clean than some of the more detailed rims.
Old Jan 23, 2007 | 11:15 PM
zand02max's Avatar
zand02max
You use wheel wax to clean your rims?
