high pressure washer
Old May 5, 2003 | 11:23 AM
tennyball's Avatar
tennyball
Default high pressure washer
Has anyone tried using a high pressure water spray to remove brake dust from their rims? It's pretty tough getting into the inner area of the rim, where most of the brake dust collects.
It would be nice to remove most of the brake dust use the high pressure spray and then hand wipe whatever is left.
Old May 5, 2003 | 12:35 PM
teh215's Avatar
teh215
I have and it doesn't come completely off. If you are using a sprayer you should probably use something like Meguirs Hot Rims to let the brake dust wash off. It is also good for getting back behind the spokes clean with no scrubbing. Be careful though when buying wheel cleaners as some of them are pretty harsh and could damage the finish on the wheels. Good Luck.
Old May 5, 2003 | 07:06 PM
DumbGenius's Avatar
DumbGenius
From: Calgary, Alberta, Canada, Earth, Solar System
It works quite well for the brake dust.
Old May 5, 2003 | 09:59 PM
ares's Avatar
ares
Veteran
it could very easily blast the dust into the clear coat rather than off the rim... something to consider.
Ive never had trouble with atleast biweekly cleaning of the rims with soap and water and a rag, take about 5 minutes per rim, and use a q tip occasionally to get into the lug nut holes and what not.
also try to get the lip behind the spokes, looks much better IMO. for the truely ****, get behind the spokes too.
Old May 6, 2003 | 08:29 PM
03 Z for ME's Avatar
03 Z for ME
Default For the Truely ****...
For those of us that are the most ****... Take the WHEEL off and clean it all... Front, back, insode, outside, lug nut hols, spokes... do it all if you're going to do it!!!
Old May 7, 2003 | 08:59 AM
ares's Avatar
ares
Veteran
guilty as charged. its much easier to clean them that way.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
