Sheet on my Z (literally!)
Old Aug 6, 2007 | 04:15 PM
twinship's Avatar
twinship
Default Sheet on my Z (literally!)
My car lives in a car port directly under the large drain pipes that carry water and sewage down to the main drain at the street. The pipes leaked around the joints and now I have crud on the roof of the Z. I assume it's sewage... kinda reddish-brown in color.
I wet it down and tried gently rubbing, to see if it would come loose, but it didn't. It's definitely above the paint cuz you can feel it raised above the surface. But it's got a firm grip on the paint.
Any suggestions? As you can imagine I'm concerned that I not scratch or remove any of the paint in the process of getting the crud off.
TIA for any words of wisdom!
Old Aug 6, 2007 | 04:48 PM
DavesZ#3's Avatar
DavesZ#3
The first thing to try is a claybar. It's great for removing contaminants from the surface of your paint.
You can also try mineral spirits/WD40 to see if it dissolves the solids.
If all that fails, there are a number of suggestions and methods on this page...
http://www.bettercarcare.com/paint-p...ng-clinic.html
Old Aug 6, 2007 | 06:13 PM
twinship's Avatar
twinship
Thx.
You mean just spray WD40 right on the affected area...? That won't harm the paint?
(Sorry if that's a dumb question, but I have no idea what's in WD40 and never would have thought of using it in this way.)
Old Aug 6, 2007 | 07:04 PM
DavesZ#3's Avatar
DavesZ#3
Yes, spray WD40 on the affected area. WD40 is a solvent, it's essentially mineral spirits which is the basic ingredient in bug and tar removers. It won't harm paint and will soften tar, sap, grease, etc. Basically, it's harmless although it's not somethign you would leave on your paint for a long period of time or let it dry in the sun, etc.
Old Aug 6, 2007 | 07:35 PM
350Z84's Avatar
350Z84
+1, works great for residue like that if the claybar doesn't work.
Old Aug 7, 2007 | 06:48 AM
Clipdin's Avatar
Clipdin
SHIFT_happens
Will it cut through your layers of Zaino??
Old Aug 7, 2007 | 09:23 AM
350Z84's Avatar
350Z84
You should hit the area with polish and wax after you have cleaned it.
Old Aug 7, 2007 | 01:57 PM
twinship's Avatar
twinship
Well, just tried the WD40 and it didn't work.
I first sprayed onto a soft towel and tried rubbing. Nada. Then I sprayed directly on the crud and let it sit for a few minutes. Again, nada.
Guess I'll have to get some claybar and give that a try. Never used it before, so this will be a new experience.
Old Aug 7, 2007 | 03:12 PM
Photos would be helpful.
Old Aug 10, 2007 | 09:15 AM
twinship's Avatar
twinship
OK, these aren't great, but it'll give you the idea...
Attached Thumbnails Sheet on my Z (literally!)-001.jpg   Sheet on my Z (literally!)-002.jpg   Sheet on my Z (literally!)-003.jpg
Old Aug 10, 2007 | 09:22 AM
Daytona350Texas's Avatar
Daytona350Texas
daaaaaamn, that does look rank, really hope you get it off it doesnt do that paint justice
sorry bro
Old Aug 10, 2007 | 03:42 PM
fairlady350z33's Avatar
fairlady350z33
hope you get that taken care of quickly. try the clay bar. the longer it sets on the paint the harder it will be to get off. GL bro.
Old Aug 10, 2007 | 04:29 PM
twinship's Avatar
twinship
Thx, guys.
Plan to try the claybar over the weekend.
Old Aug 27, 2007 | 11:22 PM
joe645733's Avatar
joe645733
buff
350z_z33.
Jul 3, 2017 04:01 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
Bigsyke
Sep 11, 2015 06:19 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
