autopia's buffer? any good?
Old Sep 19, 2007 | 10:04 AM
redlude97's Avatar
redlude97
Originally Posted by DavesZ#3
There's your problem - don't believe sales hype or specs. Always go to the source...
http://www.deltaportercable.com/Prod...roductID=11052
Power: 120 VAC, 50-60 HZ
Amps: 4.0
Orbits/Min:
Tool Length: 11-1/2
Net Weight: 5-3/4
Shipping Weight: 6-1/2
any comments? How about a picture of your 7336sp with a 4amp motor?
Old Sep 19, 2007 | 03:19 PM
DavesZ#3's Avatar
DavesZ#3
I haven't had a chance to go by and check a new one out.
Old Sep 20, 2007 | 06:44 AM
dunglan7's Avatar
dunglan7
Old Sep 20, 2007 | 07:50 AM
redlude97's Avatar
redlude97
Originally Posted by dunglan7
He didn't get owned, its very possible that the newest 7336sp's have been upgraded, but I don't think anyone has one yet.
Old Sep 20, 2007 | 08:36 AM
DavesZ#3's Avatar
DavesZ#3
According to the Delta/Porter-Cable Customer Care line, the new ones are 4 amp but the agent couldn't tell me when they were first released.
Whether the UDM is 5% or 20% or even 50% stronger, I still find it hard to believe that it can destroy a pad that works fine with the older 7336/7424 ROBs. I could see it happening if it was 5X stronger or turned 10,000 RPM (circular polisher or grinder). Pads just aren't that flimsy.
Old Sep 20, 2007 | 09:39 AM
redlude97's Avatar
redlude97
Regardless of whether the pad will seperate or not, if the UDM is 20% stronger, it should break down polishes 20% faster, and be able to generate higher levels of heat meant for some products that are really for rotory use, which IMO is a great advantage for heavy marring. I've reached the limit for what the 7424/7336sp can do with even 4" pads. Its either the UDM or rotary at this point
Jambo016
Sep 16, 2016 01:08 PM
