Crystal Guard usage question
Old Jun 1, 2003 | 07:04 PM
Nocturnal's Avatar
Nocturnal
Default Crystal Guard usage question
Can you apply CG over the plastic or rubber of the car? I know if you get wax on them, they will stick in there forever, and it is nearly impossible to get them out of the rubber trim.
I never heard any problem like this for CG, can you apply CG over the rubber, and the wind shield of the car without problems?
I heard people have put CG over wind shield with great result. Anyone can confirm?
Old Jun 2, 2003 | 04:44 AM
BillR's Avatar
BillR
I have applied it to all my windows. I kinda acts like Rain-X.
Old Jun 2, 2003 | 06:50 PM
thardwick's Avatar
thardwick
Don't worry about a thing! Cover the whole car. You won't see any residue like the way wax does. It's really easy to use. Good luck!
Old Jun 3, 2003 | 11:36 AM
customexotica1's Avatar
customexotica1
Talking
That's right, CG won't damage any parts.
Good luck!
Old Jun 8, 2003 | 07:38 AM
Nocturnal's Avatar
Nocturnal
Okay, tried it out on a friends motorcycle (scooter, they are all over Macau)
Anyways, the scooter now shine, BUT it seems to hazed the badge (Yamaha), the badge seems to be made of some clear rubber type material...any idea how to get the haze out?
Also, the scooter is silver (so is my Z), and it shine a little more, but nothing BIG I was hoping for...is it because it is silver?
Pretty good result considering I didn't do ANY prep work on it, I just wash it, spray it on, hose it off, and dry...
Should I let the CG sit on the car for an hour or so, I heard this yeild better result as the CG have alot more time to cure...but it will leave a haze.
Any tips from the PRO...I will CG my car as soon as it get out of the body shop...hopefully soon.
Old Jun 9, 2003 | 09:27 AM
Keven's Avatar
Keven
Default Sneaking in a CG usage question ...
I'm going to sneak my question in here as it does regard Crystal Guard usage and I don't want to overdo us on new folders.
This past week I applied my third layer of CG - over a span of about a month. Up until this point, I've gotten a really smooth, glossy finish. However, after this application, I've noticed as it's curing it appears to be "cracking". I'll describe this as best as I can: it looks like long horizontal surface scratchs (about the depth of swirl marks but there aren't any swirls visible). This is most evident in direct sunlight. In fact, it looks pretty bad in direct sunlight.
My first thought was a bad buffing cloth but I don't buff in straight lines - rather small circular motions and always use a clean, microfiber towel.
I honestly haven't got a clue. I'm hoping/thinking that someone here far more well versed with CG might be able to help me figure out what's going on and fix it. I appreciate any insight that might be offered.
Old Jun 11, 2003 | 02:33 PM
customexotica1
Well. Don't apply CG in direct sunlight ...........
Wash the car few times.........If it's dosen't work CG Primer can remove it.
Old Jun 11, 2003 | 03:45 PM
Keven's Avatar
Keven
Default Um, thanks ...
I didn't apply in direct sunlight ... I applied in a shaded, covered parking area. It's just very evident when the car is parked in direct sunlight, as mentioned in my previous post.
Thanks for the tip on the Primer.
Old Jun 13, 2003 | 09:54 AM
customexotica1
Smile
Thank you!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
