brake dust
Old Jan 10, 2008 | 06:43 AM
Tony07zebra's Avatar
Tony07zebra
Default brake dust
Ive got a problem with some black sht in the lug nut holes on all 4 rims (appears to be brake dust) -that I cant get off. It doesnt just wipe off. Ive tired to use my fingernail and still nothing. what kind of solvant or cleaner would take care of this without stripping the clear coat? please help. oh im a newb as well go easy
Old Jan 10, 2008 | 07:21 AM
Anomaly's Avatar
Anomaly
Have you tried using soap and water with a micro fiber towel?
If that doesn't work, try picking up a wheel cleaner (ie, P21S wheel cleaner gel) from Detailed Image.
Old Jan 10, 2008 | 08:38 AM
BriA5's Avatar
BriA5
Use p21s GEL and a long bristled boar's hair brush.
Spray the p21s gel on the wheel, concentrating on the lugnut area. Let it sit for an hour or two (p21s gel is ph neutral so this is safe). Then agitate it with the brush and some water. Rinse off.
Should do the trick.
NOTE: most wheel cleaners are not ph neutral and should not be left on a wheel for extended periods of time. p21s is an exception.
Old Jan 10, 2008 | 10:06 AM
A brush like this will help with the lug nut holes.
Old Jan 10, 2008 | 02:32 PM
BriA5's Avatar
BriA5
I just picked up a brush just like that. Branded by Swissvax.
Haven't gotten to try it out yet, but I was thinking it would be particularly good for around lug holes.
The bristles are really nice and VERY densely packed.
Old Jan 10, 2008 | 05:54 PM
ppw350zinmd's Avatar
ppw350zinmd
I had the same problem with my front wheels and used a clay bar for removal. The clay bar works wonders and will remove just about anything.
Old Feb 2, 2008 | 09:39 PM
SChetal's Avatar
SChetal
Best thing is to get a soft paint brush..
Its cheaper and has given me the same result as the 10x the price boar's hair brush...
Old Feb 2, 2008 | 09:57 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Sandpaper might work? J/K, i would def try some good soap/hot water first then escalate it if needed. LOL the AD on this is for a clorox toilet wand.
Old Feb 2, 2008 | 10:10 PM
1cleanz's Avatar
1cleanz
You could try to find a lug nut brush it makes it easy to clean aroud the lugs. also some p21s as stated above or other wheels cleaners. after cleaning if you want to or have the time pull them off and clean again. then use a clay bar to try to get the rest off if cleaning hasent worked. you could also use some dawn liquid soap and wash. but make sure to wax and protect the wheel afterwards, as the dawn will strip the wax on your wheels.
Old Feb 12, 2008 | 05:00 AM
You are welcome.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
