CLEANING CF HOOD: water spots bad
Old May 1, 2008 | 05:32 PM
Da K00l Aid Man's Avatar
Da K00l Aid Man
Default CLEANING CF HOOD: water spots bad
Ok, I've had my Seibon CF hood for under 2 yrs now, and there is tons of fading/hazing on the corners, and there are water spots on it that I can't get rid of and neither could my detailer. I need some ideas on how the heck to get this stupid hood clean lol
Anything in particular that I should be using to get it looking like new ?
Old May 1, 2008 | 05:37 PM
Jay'Z's Avatar
Jay'Z
Get it re cleared.. I did mine and it looks sickness!!
Old May 1, 2008 | 05:39 PM
SuperBlack350z's Avatar
SuperBlack350z
in what way is your detailer trying to get rid of the water spots and hazing? Either your detailer doesn't know what he is doing or you will need your hood recleared with nice clear coat and not the cheap one that comes on seibons.
Old May 2, 2008 | 03:28 AM
Da K00l Aid Man
I'm not sure what he did actually, I wasn't at the car when it was done, but I know the hood only has the crappy Seibon clear on it, I have never had it cleared. I'm just going to say screw it and eventually get a different hood.
Old May 2, 2008 | 07:12 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
I assume the hood has a clear coat on it, if not that would change my advice. Assuming it does you can try a Water Spot Remover formula for light watermarks. Often times they can etch in to the clear coat, which will require some serious polishing to remove. If they've really etched very deep in to the clear coat you may need some touch up work. Here is a very rough estimate of what I've seen when I detail. I would estimate 10% - 25% of the vehicles I see with watermarks can be removed with a cleaner like the Chemical Guys Water Spot Remover. If that doesn't work you'll need to polish which I would say can remove the imperfections from about 95%+ of the vehicles I've worked on. If you use a high speed rotary buffer with an aggressive polishing combination you should be able to buff them out. A very small percentage of vehicles have etchings that are so bad that a re-spray is in order.
I would check with your detailer and see what they have done. A quality polish job with the right products and tools should be able to restore it. I hope this helps.
Greg @ Detailed Image
Old May 2, 2008 | 09:29 AM
Da K00l Aid Man
Well I did not have the hood cleared. I simply bought it and put it on the car. I need to replace the hood anyway as the latch on my particular hood is effed anyway, but I am going to try the water spot remover to see if that helps. Thanks for the advice.
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
