Dr Bonz NEW FORMULA Zaino Experiment!
Old Jul 19, 2003 | 08:16 PM
  #61
AudioPat's Avatar
AudioPat
Up Front Enterprises
Hey Doc...clean out your mailbox...can't send you a PM
Old Oct 6, 2003 | 10:38 AM
  #62
Diesel350's Avatar
Diesel350
Default Re: Dr Bonz NEW FORMULA Zaino Experiment!
Originally posted by Dr Bonz
[B]In my soon to be released Zaino editorial, I had the honor of interviewing none other than Sal Zaino himself. I won't go into that right now as I don't want to spoil the editorial. It'll be posted at 350Zfrenzy.com soon. Look here:
Just Zay-No
BUT, I did talk to Sal about his NEW FORMULA Zaino, and after getting my shipment of it, I decided to give it a try.
Sal told me (among other things) that a light claying of the paint will NOT remove Zaino. This was good news to me since I wanted to clean the paint of any debris but I didn't want to take off my 35 layers!
So, it was off to the drawing board once again. I first washed with Z-7 wash as always and then rinsed dry. Using a brand new clay bar (Zaino # Z-18) and a dilute solution of Z-7 as a lube, I lightly clayed the entire car.
I did the old hand in the plastic bag test again and believe it or not, it was actually appreciably smoother after the claying. BUT what I did not see was loss of beading property or any sign that I had taken any Zaino off of the car! (See my editorial for Sal's explanation of this).
After the claying, I dried as I always do and did a full Z-6 misting. I then applied a layer of the NEW FORMULA Z-5. It is MUCH thinner than the old Z-5 and goes on much easier and smoother. It seems to cover the paint a lot more thoroughly as well. I used the Z-5 mixed with ZFX so I could do it all in one day.
Upon taking off the Z-5, I noted that it was also a bit easier to remove than before. I did another Z-6 misting and then applied a layer of the NEW FORMULA Z-2. It too is thinner than it's old version and again, it went on smoother and came off just as easy.
The pics and the final result are below. I think Sal has once again, outdone himself! It may have a lot to do with the fact that I clayed the car, but it looks and feels GREAT! I got that same old EYE-POPPING look I got the very first time I Zaino-ed the Z.
Couple questions with this formula:
1.How long did it take you to do all this?
2.Do you clay your car everytime you wax your car?
3.Do you wipe the clear residue off and then apply Z-6 or do you apply z-6 while the clay residue is still on?
4. When you apply the z-6 does that need to be wiped off as well before you apply z-5?
5. Do you apply the clay, z-5, z-6, z-2 in sections or the entire car at once?
6. What's the difference in z-2 and z-5? They are both polishes. Will I get the same results if I just use one or the other?
7. How much of a difference does ZFX make?
8. How much of a difference does z-6 make?
Old Oct 6, 2003 | 01:57 PM
  #63
SungNamZ's Avatar
SungNamZ
I might suggest that you go to www.zaino.com and look at each of the products you have questions on. There is also a very good "Tips & Tricks" section. I will say this, it is by far the "finest" product I have ever used! Not only the finest, but the "easiest". Would not have applied 29 coat since mid August if difficult. That is 29 of Z5 and Z2. How many Z6 ?????. It goes on after you wash. Goes on after Z5 and before Z2. Goes on as last process. Goes on if you just want a clean "wet" look before going out. That assuming your car has been dusted with "California Duster".
Old Oct 6, 2003 | 07:12 PM
  #64
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
1.How long did it take you to do all this? ABOUT 4 HOURS BUT ONLY FOR THE FIRST TIME, AFTER THAT EVERY LAYER ONLY TAKES ABOUT AN HOUR
2.Do you clay your car everytime you wax your car? NO, ONLY DID IT TWICE IN A YEAR
3.Do you wipe the clear residue off and then apply Z-6 or do you apply z-6 while the clay residue is still on? THERE SHOULDN'T BE ANY "CLAY RESIDUE". AFTER YOU CLAY YOU WASH THE CAR AGAIN, THEN DRY, THEN Z-6.
4. When you apply the z-6 does that need to be wiped off as well before you apply z-5? YES, Z-6 IS MIST ON, BUFF OFF IMMEDIATELY WITHOUT LETTING IT DRY.
5. Do you apply the clay, z-5, z-6, z-2 in sections or the entire car at once? ENTIRE CAR AT ONCE
6. What's the difference in z-2 and z-5? They are both polishes. Will I get the same results if I just use one or the other? Z-5 IS BETTER FOR FILLING IN SWIRLMARKS BUT STILL SHINES VERY WELL. Z-2 IS MORE "OPTICALLY PERFECT" AND I ALWAYS USE THAT LAST.
7. How much of a difference does ZFX make? IT MAKES IT A MUCH FASTER PROCESS. YOU CAN DO A LAYER AND REMOVE IT IN UNDER AN HOUR. WITHOUT ZFX, IT NEEDS TO SIT AND CURE FOR AT LEAST 10-12 HOURS.
8. How much of a difference does z-6 make? I BIG DIFFERENCE. IT PREPS THE SURFACE NICELY TO ACCEPT THE POLISH. ALSO, IT IS GREAT FOR QUICK DETAILING WITHOUT APPLYING ANY Z-2 OR Z-5.
Old Oct 7, 2003 | 12:50 PM
  #65
SpoonieLuv's Avatar
SpoonieLuv
how long should I let it dry before removing the Zaino?
Old Oct 7, 2003 | 02:34 PM
  #66
SungNamZ's Avatar
SungNamZ
It depend! Did you use "ZFX"? Look at the previous post by Dr Bonz. With "ZFX" could be buffing in a hour or less depending on temp and humidity. Without, 10 - 12 hours. I do both. Lately been washing with Z7, follow-up with Z6, apply Z2 without "ZFX" and let it sit in the garage overnight to dry.
Old Oct 7, 2003 | 06:04 PM
  #67
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
DITTO
Old Oct 7, 2003 | 10:13 PM
  #68
Buub's Avatar
Buub
Is that Yosemite Sam reflected in the rear fender?!
Old Oct 8, 2003 | 03:08 AM
  #69
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yeah, he and Foghorn Leghorn helped me apply the 50th Layer.
Old Oct 8, 2003 | 01:26 PM
  #70
bhobson333's Avatar
bhobson333
Damn, Bonz, you gotta stop drinkin' that sh*t!
Old Oct 12, 2003 | 06:06 PM
  #71
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Zaino Now Allowed on the Adkins Diet!!!
Found to be Low in Carbs!!!
Old Oct 13, 2003 | 01:22 PM
  #72
bhobson333's Avatar
bhobson333
No, no, no, that's SHOW CAR wash, not Low Carb wash.
Old May 19, 2004 | 06:19 PM
  #73
sluggo20031's Avatar
sluggo20031
Years later and you are still adding that Zaino-- bought mine 11/02 and I only have 4 coats of Zaino -- yet in 2/03 you had like 20 coats already Bonz -- slackin there
Old May 19, 2004 | 07:41 PM
  #74
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Keep sluggin away Sluggo.
I just slapped on layers number 61 and 62 today.
Leavin' for NC in the AM where I will be applying some more during my detailing sessions.
See some of you there!
Old May 22, 2004 | 06:25 AM
  #75
g35cfan's Avatar
g35cfan
Wow, 60+ layers Bonz?!?! Impressive! I have failed the Zaino gods. I have not Zainoed in about 4 months But the 15 layers I had on are still going strong. Now with the pollen gone, I'm going to clay bar and Zaino my baby again. What can I say? After a year, the new car feeling as dissipated a bit. I've been lazy.
Old May 23, 2004 | 10:18 AM
  #76
Reggi914's Avatar
Reggi914
Doc, just wondering how many bottles of zaino you bought? I am just wondering hom many bottles of zaino it takes to put on 60 coats. I know that you probably bought way more z-6, but im just talking about z2 and z5.
Old May 23, 2004 | 08:27 PM
  #77
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I went through one bottle of Z-2 original formula and am half way through my bottle of new formula Z-2. I have been through two bottles of original Z-5 and just started on my second bottle of new formula Z-5.......so to answer your question I have used approximately 4.5 bottles so far (in two years and 63 total layers on my Z, three layers on my sister's SLK, 6 layers on my wife's Jeep, three layers on my dad's Jag, one layer each on Andy's and Morris' cars at Z Dayz).
As for the Z-6, I've lost count. Probably around 6-8 bottles total.
Old May 24, 2004 | 06:45 PM
  #78
ranger5oh's Avatar
ranger5oh
wow.. those reflection shots are awesome.
Honestly though, the new Meguires NXT works just as well and much much cheaper. (no flaming intended)
Old May 24, 2004 | 07:40 PM
  #79
bhobson333's Avatar
bhobson333
Flaming taken. You'd better get your numbers together. Rumors of Zaino being more expensive are wildly exaggerated by haters. When you look at coat-by-coat costs and relative protection, Zaino definitely holds its own.
What are you basing your claims on?
Old May 24, 2004 | 08:07 PM
  #80
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I'm sorry but you just cannot argue with this:
Attached Thumbnails Dr Bonz NEW FORMULA Zaino Experiment!-the-brick-2-small-.jpg
