NEW!!!! Daily Specials at Detailed Image
Old Aug 10, 2010 | 01:01 PM
  #721
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (August 10, 2010) is Chemical Guys Pete's & 53 Black Pearl Signature Paste Wax.
Regular Price for 8 oz is $53.99. Today's price is $38.87!
  • A hidden gem of carnauba waxes, offering excellent depth and gloss and easy application
  • Excels on darker colored vehicles, but works well on any color, metallic and non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old Aug 11, 2010 | 07:28 AM
  #722
Detailed Image
Detailed Image
Today's Daily special (August 11, 2010) is Dodo Juice Rainforest Rub Soft Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice soft carnauba wax designed to work on any colored vehicle, light or dark
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Can be applied with a foam applicator pad or literally with your bare hands
  • Dodo Juice soft waxes offer slightly more depth and gloss over the Dodo Juice hard waxes
  • Remove any Dodo Juice wax with a plush microfiber towel
Old Aug 12, 2010 | 05:48 AM
  #723
Detailed Image
Detailed Image
Today's Daily special (August 12, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.83!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
Old Aug 13, 2010 | 06:15 AM
  #724
Detailed Image
Detailed Image
Today's Daily special (August 13, 2010) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $13.99. Today's price is $10.21!
  • Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
  • Effective even at a 10:1 dilution ratio making this an extremely good value
  • Works well in carpet extractors due to the low sudsing formula
  • Dilute and dispense using a 22 oz trigger spray bottle
Old Aug 14, 2010 | 06:25 AM
  #725
Detailed Image
Detailed Image
Today's Daily special (August 14, 2010) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old Aug 17, 2010 | 05:58 AM
  #726
Detailed Image
Detailed Image
Today's Daily special (August 17, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $17.99. Today's price is $13.40!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old Aug 22, 2010 | 11:47 AM
  #727
Detailed Image
Detailed Image
Today's Daily special (August 22, 2010) is DI Accessories White Bucket with Handle.
Regular Price for 5 gallon is $9.99. Today's price is $7.29!
  • Made out of durable high density polyethylene
  • Plastic handle and tapered design
  • Grit Guard Bucket Insert is highly recommended
Old Aug 24, 2010 | 08:46 AM
  #728
Detailed Image
Detailed Image
Today's Daily special (August 24, 2010) is P21S Metal Polishing Soap.
Regular Price for 10.5 oz is $9.99. Today's price is $8.28!
  • Cleans, restores, polishes, and protects metal surfaces to a brilliant finish in 1 easy step
  • Includes a sponge applicator pad that conveniently stores itself in the top of the jar
  • Soak supplied sponge in warm water, wring out, swipe across soap, then polish the metal
  • For best results, clean the area prior to polishing with soap and water
  • Remove excess product with a quality microfiber towel
Old Aug 26, 2010 | 09:32 AM
  #729
Detailed Image
Detailed Image
Today's Daily special (August 26, 2010) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Old Aug 29, 2010 | 09:47 AM
  #730
Detailed Image
Detailed Image
Today's Daily special (August 29, 2010) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Old Sep 2, 2010 | 10:03 AM
  #731
Detailed Image
Detailed Image
Today's Daily special (September 2, 2010) is Chemical Guys Hose Free ECOwash.
Regular Price for 16 oz is $12.99. Today's price is $9.48!
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Old Sep 3, 2010 | 08:12 AM
  #732
Detailed Image
Detailed Image
Today's Daily special (September 3, 2010) is Poorboy's World Bug Squash.
Regular Price for 16 oz is $10.99. Today's price is $8.19!
Regular Price for 32 oz is $15.99. Today's price is $11.67!
  • Paint safe, pre-wash degreaser designed to break up stubborn contamination prior to washing
  • Helps loosen bug splatter, tar, sap, bird droppings, and other forms of contamination
  • Concentrated solution which should be diluted down to a 3:1 ratio with distilled water
  • Remember to protect the areas you use Bug Squash on with a sealant or wax
  • For easy dilution and usability, we recommend a 22 oz spray bottle or a convenient 4 oz pump bottle
Old Sep 6, 2010 | 06:31 AM
  #733
Detailed Image
Detailed Image
Today's Daily special (September 6, 2010) is Chemical Guys Speed Wipe (Anti-Static) Quick Detailer.
Regular Price for 16 oz is $8.99. Today's price is $7.00!
  • An outstanding quick detailer that is perfect to use after a maintenance wash and dry
  • Leaves behind a slick surface that is anti-static which helps minimize dust build ups
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Old Sep 8, 2010 | 08:01 AM
  #734
Detailed Image
Detailed Image
Today's Daily special (September 8, 2010) is P21S Windshield Wash Booster.
Regular Price for 250 ml is $8.99. Today's price is $6.56!
  • Increase the cleaning power of your current windshield washer fluid
  • Helps improve visibility, which helps you drive safer in poor weather conditions
  • Simply pour some P21S Windshield Washer Booster into your existing washer fluid!
Old Sep 10, 2010 | 08:02 AM
  #735
Detailed Image
Detailed Image
Today's Daily special (September 10, 2010) is Chemical Guys Go Green! Waterless Wash.
Regular Price for 16 oz is $12.99. Today's price is $9.68!
  • Our most versatile spray on product that cleans, polishes, enhances gloss and protects your paint
  • Use as a waterless wash to remove a light coating of contamination without marring your finish
  • Perfect option to keep in your glove box to clean up bird droppings and other contamination
  • To minimize adding swirls and imperfections, use a plush microfiber towel to wipe and buff
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense ONE
Old Sep 11, 2010 | 08:32 PM
  #736
Detailed Image
Detailed Image
Today's Daily special (September 12, 2010) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.43!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old Sep 13, 2010 | 10:51 AM
  #737
Detailed Image
Detailed Image
Today's Daily special (September 13, 2010) is Poorboy's World Super Swirl Remover 1 (SSR 1).
Regular Price for 16 oz is $15.99. Today's price is $11.35!
  • Designed to remove very light surface imperfections or hazing and improve the depth and gloss of the paint
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG, typically using a white or black pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old Sep 14, 2010 | 02:00 PM
  #738
Detailed Image
Detailed Image
Today's Daily special (September 14, 2010) is Gilmour Foamaster II Foam Gun.
Regular Price for 1/4 Gallon Tank is $59.99. Today's price is $43.79!
  • An outstanding wash tool that can help minimize adding imperfection and adds in some fun
  • Pre-soak your car with a layer of sudsy shampoo before ever touching your car with your wash mitt
  • Helps get shampoo in those hard to reach areas, such as in the wheel wells and engine bay
  • Change the dilution ratio with the spin of a dial
Old Sep 15, 2010 | 10:52 AM
  #739
Detailed Image
Detailed Image
Today's Daily special (September 15, 2010) is Klasse All In One (AIO).
Regular Price for 500 ml is $27.99. Today's price is $21.28!
Regular Price for 1000 ml is $39.99. Today's price is $30.40!
  • A must have for anyone looking for an all in one (AIO) product that cleans and protects
  • A strong chemical cleaner that can remove oxidation, water spots, and other surface imperfections
  • Leaves behind an acrylic layer of protection that lasts months
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
  • When using a buffer, best applied with a white polishing pad or black finishing pad
Old Sep 16, 2010 | 10:01 AM
  #740
Detailed Image
Detailed Image
Today's Daily special (September 16, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
