NEW!!!! Daily Specials at Detailed Image
Old Oct 29, 2010 | 07:17 AM
  #781
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (October 29, 2010) is Menzerna Final Finish.
Regular Price for 32 oz is $29.99. Today's price is $21.29!
  • A great finishing polish, designed to remove hazing, holograms and light surface imperfections
  • Restores depth and gloss to the paints finish and is easy to work with
  • Easy to remove when worked into the paint properly
  • Recommended application is using a buffer with a white polishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle
Old Oct 30, 2010 | 05:48 AM
  #782
Detailed Image
Detailed Image
Today's Daily special (October 30, 2010) is Poorboy & World Bold & Bright Tire Gel.
Regular Price for 16 oz is $11.99. Today's price is $8.75!
  • Gel based version of the very popular Poorboy's Bold 'n Bright
  • Long durable tire shine that is easy to apply and does not sling!
Old Oct 31, 2010 | 10:27 AM
  #783
Detailed Image
Detailed Image
Today's Daily special (October 31, 2010) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.80!
Regular Price for 32 oz is $49.99. Today's price is $36.49!
  • Our best selling finishing polish that removes light imperfections and lots of depth and gloss
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a white polishing pad for a great combination of cut and gloss
  • Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Old Nov 3, 2010 | 12:18 PM
  #784
Detailed Image
Detailed Image
Today's Daily special (November 3, 2010) is 303 High Tech Fabric Guard.
Regular Price for 16 oz is $14.99. Today's price is $10.64!
Regular Price for 32 oz is $26.99. Today's price is $19.97!
  • Protects carpet, canvas and upholstery from staining by repelling liquids
  • Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
  • Works great on canvas convertible tops and outdoor patio furniture
  • For maximum efficiency use in a 4oz pump spray bottle
Old Nov 4, 2010 | 07:01 AM
  #785
Detailed Image
Detailed Image
Today's Daily special (November 4, 2010) is Lake Country Green Very Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
  • A very popular polishing pad designed to remove light surface imperfections from the paint
  • When you need a tad more bite than a white polishing pad, the green pad is your answer
  • Menzerna PO106FF polish is one of the most popular products to use with the green pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Nov 5, 2010 | 09:00 AM
  #786
Detailed Image
Detailed Image
Today's Daily special (November 5, 2010) is DI Accessories Medium Grade Clay Bar.
Regular Price for 200 g is $18.99. Today's price is $14.15!
Regular Price for 100 g is $10.99. Today's price is $7.80!
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
Old Nov 6, 2010 | 11:14 AM
  #787
Detailed Image
Detailed Image
Today's Daily special (November 6, 2010) is Optimum (OPT) Metal Polish.
Regular Price for 8 oz is $9.99. Today's price is $7.85!
Regular Price for 32 oz is $32.49. Today's price is $23.72!
  • Polish your metal to a high level of depth and gloss with the Optimum Metal Polish
  • Apply with a foam applicator pad and remove with a quality microfiber towel
  • Most commonly used on wheels, exhaust tips, interior and exterior metal and chrome trim
Old Nov 7, 2010 | 06:04 AM
  #788
Detailed Image
Detailed Image
Today's Daily special (November 7, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.37!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old Nov 8, 2010 | 09:59 AM
  #789
Detailed Image
Detailed Image
Today's Daily special (November 8, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $19.99. Today's price is $14.89!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old Nov 9, 2010 | 06:24 AM
  #790
Detailed Image
Detailed Image
Today's Daily special (November 9, 2010) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.21!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old Nov 10, 2010 | 06:40 AM
  #791
Detailed Image
Detailed Image
Today's Daily special (November 10, 2010) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.51!
  • Designed to remove moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG, typically on an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old Nov 11, 2010 | 07:22 AM
  #792
Detailed Image
Detailed Image
Today's Daily special (November 11, 2010) is Meguiar's All Purpose Cleaner D101.
Regular Price for 128 oz is $13.99. Today's price is $10.21!
  • Perfect for carpet, upholstery, vinyl and leather surfaces
  • Concentrated formula works effectively at a 10:1 dilution ratio
  • Agitate stubborn stains with a medium bristled brush for maximum results
  • Exceptional value for detailers and enthusiasts
  • Dilute and dispense using a 22 oz trigger spray bottle
Old Nov 12, 2010 | 09:35 AM
  #793
Detailed Image
Detailed Image
Today's Daily special (November 12, 2010) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
Regular Price for 16 oz is $16.99. Today's price is $12.40!
Regular Price for 128 oz is $84.99. Today's price is $60.34!
  • pH balanced wheel cleaner safe on ALL wheel finishes and competes amongst the best wheel cleaners available
  • Powerful concentrated suspension allows for dilution of product without the loss of cleaning power, making it a great value
  • Perfect for high end professional detailers who detail expensive wheels
Old Nov 13, 2010 | 06:40 AM
  #794
Detailed Image
Detailed Image
Today's Daily special (November 13, 2010) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $6.99. Today's price is $5.10!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old Nov 14, 2010 | 05:27 AM
  #795
Detailed Image
Detailed Image
Today's Daily special (November 14, 2010) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 4 inch is $4.99. Today's price is $3.69!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Old Nov 15, 2010 | 03:52 PM
  #796
Detailed Image
Detailed Image
Today's Daily special (November 15, 2010) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $14.79!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Old Nov 16, 2010 | 03:49 PM
  #797
Detailed Image
Detailed Image
Today's Daily special (November 16, 2010) is Chemical Guys Clear Seal.
Regular Price for 16 oz is $9.99. Today's price is $8.68!
  • Clean, polish and protect all of your plastic surfaces, in one easy to use step
  • Leave plastic surfaces with a slick layer of protection to help minimize dust from building up
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle and applying with a microfiber towel
Old Nov 17, 2010 | 08:19 AM
  #798
Detailed Image
Detailed Image
Today's Daily special (November 17, 2010) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
Old Nov 18, 2010 | 11:57 AM
  #799
Detailed Image
Detailed Image
Today's Daily special (November 18, 2010) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.43!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old Nov 19, 2010 | 05:36 AM
  #800
Detailed Image
Detailed Image
Today's Daily special (November 19, 2010) is Meguiar's Scratch X 2.0.
Regular Price for 7 oz is $9.49. Today's price is $7.07!
  • Remove swirls, fine scratches and other imperfections
  • Can be applied effectively by hand or with a buffer
  • Restores a deep glossy finish while removing imperfections
  • Follow up with your favorite choice of protection
  • Commonly applied with a foam applicator pad
