NEW!!!! Daily Specials at Detailed Image
Today's Daily special (January 9, 2011) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 15" is $8.99. Today's price is $6.47!
- Thickest, softest, most plush towel we carry.
- Over 3x thicker than regular microfiber towels.
- Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Today's Daily special (January 10, 2011) is Chemical Guys Stripper Scent - Smell of Success.
Regular Price for 16 oz is $11.99. Today's price is $9.16!
Today's Daily special (January 11, 2011) is P21S Finish Restorer.
Regular Price for 75 ml is $9.99. Today's price is $8.27!
- Clean, restore and polish your wheels and metal trim in one easy step
- A little goes a long way, work a small amount of product into the metal with light pressure
- We recommend using a foam applicator pad for application
- Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Today's Daily special (January 12, 2011) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
Regular Price for 16 oz is $16.99. Today's price is $12.06!
Regular Price for 128 oz is $84.99. Today's price is $60.34!
- pH balanced wheel cleaner safe on ALL wheel finishes and competes amongst the best wheel cleaners available
- Powerful concentrated suspension allows for dilution of product without the loss of cleaning power, making it a great value
- Perfect for high end professional detailers who detail expensive wheels
Today's Daily special (January 14, 2011) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $34.99. Today's price is $26.34!
- When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
- Works best after correcting paint imperfections with more aggressive polishes
- Easy to work with, with long work times and easy removal when properly broken down
- Most commonly applied with a black or blue finishing pad when used on a buffer
Today's Daily special (January 16, 2011) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $8.99. Today's price is $6.47!
Regular Price for 128 oz is $26.99. Today's price is $20.46!
- One of our most powerful degreasers available, designed to easily cut through contamination
- Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
- Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (January 18, 2011) is Menzerna Super Intensive Polish PO83.
Regular Price for 32 oz is $44.99. Today's price is $32.39!
Regular Price for 16 oz is $29.99. Today's price is $21.29!
- Our best medium cutting polish that is known to remove moderate imperfections in the clear coat
- Most noted for its ability to cut well, good work time, easy removal process and great finish
- On lighter colored vehicles, it is not always necessary to follow up with a finer polish
- On darker colored vehicles, we recommend following up with a finer polish, such as PO106FF
- Most commonly applied with an orange light cutting pad when using a buffer
Today's Daily special (January 20, 2011) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $9.93!
- Perfect maintenance shampoo that enhances gloss and depth
- Lots of lubricity and slickness to help minimize adding imperfections
- Concentrated formula means only a little product is needed per wash
- Best used with a grout sponge or sheepskin wash mitt
Today's Daily special (January 21, 2011) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
- Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
- Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
- To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
- We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (January 23, 2011) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.47!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (January 25, 2011) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.69!
- Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
- Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
- Jet Seal 109 is one of the most popular sealants to apply with a blue pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (January 26, 2011) is DI Accessories Industrial Strength Latex Glove - Powder Free.
Regular Price is $0.35. Today's price is $0.25!
- Large powder free glove that is 5 mil thick, making for a high quality latex glove
- Perfect to wear when using a clay bar and during the application of strong chemicals like wheel cleaners, degreasers, etc.
- Keeps your hand dry while washing
- Big savings with quantity discounts
Today's Daily special (January 27, 2011) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.73!
Regular Price for 32 oz is $49.99. Today's price is $38.19!
- Our best selling finishing polish that removes light imperfections and lots of depth and gloss
- Most commonly applied with a white polishing pad for a great combination of cut and gloss
- Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Today's Daily special (January 28, 2011) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
- A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
- Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
Today's Daily special (February 1, 2011) is Lake Country 5" Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.40!
- Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
- Get optimal results with the 5.5" Lake Country foam and wool pads
- Allows you to easily put on new pads and pull of the old ones in just seconds
Today's Daily special (February 6, 2011) is P21S Total Auto Wash.
Regular Price for 1000 ml Kit is $16.99. Today's price is $13.81!
Regular Price for 5000 ml is $64.99. Today's price is $46.14!
- One of the most versatile products we offer, degrease nearly any surface safely and effectively
- Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
- Can be used at full strength or diluted down to clean more delicate surfaces
- Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
- A must have any detailing enthusiasts or pro detailers arsenal of products
Today's Daily special (February 8, 2011) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
- Great polishing power with the ability to finish down haze and marring free
- Hydro Tech foam keeps more polish on the surface of the pad for long work time
- Experience less dusting than traditional foam pads due to less product buildup
- Save time and improve your results!
Today's Daily special (February 9, 2011) is Lake Country Green Very Light Cutting Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
- A very popular polishing pad designed to remove light surface imperfections from the paint
- When you need a tad more bite than a white polishing pad, the green pad is your answer
- Menzerna PO106FF polish is one of the most popular products to use with the green pad
Today's Daily special (February 10, 2011) is Chemical Guys Clear Seal.
Regular Price for 16 oz is $12.99. Today's price is $9.88!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Clean, polish and protect all of your plastic surfaces, in one easy to use step
- Leave plastic surfaces with a slick layer of protection to help minimize dust from building up
- For accurate product dispensing, we recommend using a 4oz dispenser bottle and applying with a microfiber towel
Today's Daily special (February 11, 2011) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.06!
- A citrus degreaser designed to help release product and contamination from foam pads
- Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
- To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
