NEW!!!! Daily Specials at Detailed Image
Today's Daily special (December 14, 2010) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
- The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
- Optimum Hyper Compound is a great polish to use with a yellow cutting pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (December 15, 2010) is Chemical Guys Black on Black.
Regular Price for 11 oz is $12.99. Today's price is $9.48!
- One of the most unique trim restorers that turns faded trim back to a deep factory black finish
- Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
- Formerly referred to as Chemical Guys Fade 2 Black
Today's Daily special (December 16, 2010) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.44!
Regular Price for 128 oz is $32.99. Today's price is $24.41!
- Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
- Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
- Works well in a Gilmour Foam Gun
Today's Daily special (December 17, 2010) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $6.99. Today's price is $5.03!
- Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
- Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Today's Daily special (December 18, 2010) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.37!
- Safely and effectively remove tar, grease and sap from painted surfaces
- Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
- Remember to protect the areas you use Tarminator on with a sealant or wax
Today's Daily special (December 19, 2010) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.19!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.69!
- Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
- Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
- Jet Seal 109 is one of the most popular sealants to apply with a blue pad
Today's Daily special (December 21, 2010) is Meguiar's Ultra Finishing Polish M205.
Regular Price for 32 oz is $27.99. Today's price is $20.71!
Regular Price for 128 oz is $84.99. Today's price is $61.19!
Regular Price for 8 oz is $9.49. Today's price is $7.07!
- Removes swirls and light imperfections on any type of paint
- Finishes down haze, hologram and marring free
- Perfect follow up to Meguiar's Ultra Cut Compound 105
- Commonly used with a white polishing pad or a black finishing pad
Today's Daily special (December 22, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $13.40!
- Extend the protection of any sealant or wax
- Increase gloss and depth of your paint, perfect for after a wash
- Promotes tight water beading which helps minimize water spots
- Applies and removes easy with a plush microfiber towel
Today's Daily special (December 24, 2010) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.83!
- Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
- Restore clarity to clear plastics by removing stains and imperfections
- Leaves behind a polymer protection for easier maintenance
Today's Daily special (December 27, 2010) is Chemical Guys Bug Bugger & Tar Remover.
Regular Price for 16 oz is $9.99. Today's price is $7.09!
- Remove tar, bug splatter, sap, and other stubborn forms of contamination with ease
- Simply spray the product onto the paint, allow Bug Bugger to dwell for a bit, agitate and rinse away contamination
- For maximum efficiency and easy storage use in a 4oz pump spray bottle
Today's Daily special (December 28, 2010) is Glass Science Rain Clear.
Regular Price for 5 oz + Bonus is $5.99. Today's price is $4.54!
- Sheet rain and water off of your glass when you have it protected with Rain Clear Gel
- Help maximize your visibility when driving in bad weather conditions
- For a streak free finish, try to apply as thin as possible to your glass, then buff clean
- Includes a sample of Glass Science Glass Scrub
Today's Daily special (December 29, 2010) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $14.89!
- Soft core foam allows for easier maneuverability compared to stiffer backing plates
- Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
- Durable one piece construction ensures a long life
- Works best with 5.5" pads or larger
Today's Daily special (December 30, 2010) is Squash Air Giga Vent Clip Air Freshener.
Regular Price is $9.99. Today's price is $7.44!
- A fresh, unique smelling air freshener that keeps your car smelling great for weeks
- Attaches to one of your vents for a fresh scent every time you run the AC or heat
- JDM squash scented air freshener
Today's Daily special (December 31, 2010) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.97!
Regular Price for 32 oz is $14.99. Today's price is $11.17!
Regular Price for 128 oz is $32.99. Today's price is $27.76!
- Quick and easy waterless wash product for lightly contaminated vehicles, an excellent clay bar lubricant and perfect for quick clean ups
- Extremely versatile cleaning product that is a favorite amongst professional detailers and enthusiasts
- Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
- Best applied with a plush microfiber towel to minimize any micro-marring in the paint
- For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (January 1, 2010) is Chemical Guys 50/50 Limited Series Concourse Paste Wax.
Regular Price for 8 oz is $59.99. Today's price is $46.38!
- Bang for the buck, one of the best carnauba waxes we offer
- Offers outstanding depth and gloss as well as sharp reflections on any colored vehicle, light, dark, metallic or non-metallic
- Easy to apply and remove when applied properly, which is as thin as possible
- Best applied with a foam applicator pad and removed with a microfiber towel
Today's Daily special (January 2, 2010) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $13.99. Today's price is $10.21!
- Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
- Effective even at a 10:1 dilution ratio making this an extremely good value
- Works well in carpet extractors due to the low sudsing formula
- Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (January 3, 2011) is Chemical Guys Synthetic Quick Detailer.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $27.99. Today's price is $23.55!
- A favorite quick detailer amongst professional detailers due to its outstanding shine and slickness
- Works great as a clay bar lubricant
- An ideal product to use after a wash to enhance the depth and gloss of your paint
- We recommend using a plush microfiber towel to apply the Synthetic Quick Detailers
Today's Daily special (January 4, 2011) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $10.64!
Regular Price for 128 oz is $39.99. Today's price is $28.79!
- Concentrated all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
- Cleaning action increases with warm water, agitation, and longer dwell time
- Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (January 6, 2011) is P21S Gel Wheel Cleaner.
Regular Price for 500 ml Kit is $17.99. Today's price is $14.21!
Regular Price for 1000 ml is $24.99. Today's price is $18.96!
Regular Price for 5000 ml is $99.99. Today's price is $80.16!
- One of the safest, most effective, pH balanced wheel cleaners on the market
- Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
- Perfect option for after market wheels as it is safe for virtually any wheel surface
- Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
- Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Today's Daily special (January 7, 2011) is Optimum (OPT) No Rinse Wash & Shine New Formula (ONR).
Regular Price for 32 oz is $15.99. Today's price is $11.91!
Regular Price for 128 oz is $39.99. Today's price is $30.88!
- Improved formula released in Feb 2010, experience increased lubricity and a more pleasant smell
- Properly wash your car without the need for a hose source
- Can also be used as a quick detailer and clay bar lubricant
- Go-to product for many professional detailers
