Remove Detailer From Headlights?
Old Aug 2, 2008 | 03:08 PM
Master Shake's Avatar
Master Shake
Default Remove Detailer From Headlights?
I got some detailer on my headlights, and now there is a foggy/hazy buildup that I cannot remove. Does anyone have any suggestions? Or is this a replace the plastic headlight covers issue now? (there's more than just a little on there )
The detailer was Mother's Showtime Instant Detailer.
So far, I've tried:
Water
Glass cleaner
Meguiar's car wash soap
Dish soap
Lots of rubbing/buffing with a microfiber towel
None of the above makes any difference.
Old Aug 2, 2008 | 04:26 PM
35Z's Avatar
35Z
Default Plastic cleaner
Try any brand of plastic cleaner available at most auto stores or auto web sites. I have purchased various plastic cleaners/polishers from Eastwood and Griot garage in the pass. I use a porter cable polisher set on no. 3 with a soft (white pad) and clean up with a microfiber towel.
Old Aug 2, 2008 | 06:23 PM
JMT's Avatar
JMT
Try this:
Available at most auto supply places.
Old Aug 2, 2008 | 07:13 PM
Looks like you tried everyone except polish.
Old Aug 2, 2008 | 07:50 PM
Get_Zwole's Avatar
Get_Zwole
yeah just use some abraisive polish should take it right off.
Old Aug 5, 2008 | 08:33 AM
Master Shake
Thanks for the suggestions.
Tried the PlastX polish, but still no change. For what it's worth, the covers still look fine when they are wet. The problem only shows when dry again. I have a feeling the plastic headlight covers are permanently etched...
Any other suggestions?
Old Aug 11, 2008 | 05:32 PM
gmic350z's Avatar
gmic350z
once youv tried all you can ,take it to body shop and they can water sand them with like 1500 grit paper and buff them out they will look new again..did it to mine ,they were getting hazzy around the edges and they look great.cheap fix
Old Aug 11, 2008 | 08:40 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
The Meg's Plastx will only last a week if you're lucky, found this from experience.
I did my headlights 6 months ago, they only need re-doing now, which is brilliant going. I used the Turbo Wax Headlight Restoration, especially designed for the purpose. I would be exceptionally surprised if you don't get a good result. I'd take a photo of the before and after but it's almost dusk here, so not the best photo time or for doing before and afters, and it's raining.
http://www.turbowax.com/cat/head-light-restoration/
Old Aug 12, 2008 | 04:30 AM
BriA5's Avatar
BriA5
Have you tried some clay bar on them? Give that a shot before you go the drastic route with wetsanding, etc.. It may be an easy fix.
Old Aug 12, 2008 | 02:48 PM
quakerroatmeal's Avatar
quakerroatmeal
Try claybar, then try to polish them.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
