Z-5/ZFX Overnight
Old Oct 22, 2003 | 06:27 PM
zand02max's Avatar
zand02max
Default Z-5/ZFX Overnight
Can I leave the Z-5/ZFX mixture on my car overnight? I know I can leave the Z-2, but I am not sure about the Z-5 /ZFX mixture. It is like 40-50 degrees outside, and will warm up to 70 tomorrow.
My car is in a garage.
Or, should I wait until tomorrow, or would it be best to do it tonight and let the Z-5 sit overnight?
Old Oct 22, 2003 | 07:16 PM
zand02max's Avatar
zand02max
Sine, I didn't get any replies, I'll wait until morning and apply the Z-5/Z-2. I was just trying to save time by doing some tinight.
Old Oct 22, 2003 | 07:17 PM
zand02max's Avatar
zand02max
And my spelling sux tonight, glad I didn't Zaino, I'm tired, LOL!
Old Oct 22, 2003 | 07:20 PM
SungNamZ's Avatar
SungNamZ
Default Re: Z-5/ZFX Overnight
I don't see a problem with doing so. It is a waste of ZFX if you plan on doing it this way. Your weather seems warm enough, especially with you having a garage. NM weather gets down to the mid 40's this time of year on a regular basis, but get up to high 70's or low 80's
I do the overnight thing with Z5 and Z2 without ZFX quite often. I think the overnight drying gives a nice, perhaps a better shine. You are not rushing it. You know it is dry. I believe either Dr Bonz of Zaino Sal suggests using ZFX on a regular basis, (i.e. every few applications) for the "bonding" effect of the Zaino Polish.
Old Oct 22, 2003 | 07:22 PM
SungNamZ's Avatar
SungNamZ
If someone had not been at the front door, would have posted before your last post. You could have done your thing. Sorry!
Old Oct 22, 2003 | 10:12 PM
afr0puff's Avatar
afr0puff
During the dead of winter I had to use ZFX if I was going to do the overnight application and morning buffing deal. It took 3 days for plain Z2 to cure on my car once when we had a string of 40 degree days.
Old Oct 23, 2003 | 07:08 AM
zand02max's Avatar
zand02max
Stupid ?, but do you need to use ZFX with Z-2 or use it only with Z-5.
I know ZFX cures it faster, but thought i would ask.
Old Oct 23, 2003 | 08:49 AM
Kevin V's Avatar
Kevin V
ZFX is used with Z-2 and Z-5. It only HAS to be applied for the first application, twice a year or every 10 coats of polish. However, I prefer to use the ZFX every time whether I'm applying Z-2 or Z-5.
Yes, you can leave polish on the car overnight without any problems and buff it off in the morning. You want to use up any ZFX/polish mix within 12 hours, 6 hours is even better. After a time the mix goes back to just polish and you have wasted the ZFX if it hadn't been applied to the car. Only mix up what you have time to apply.
Old Oct 27, 2003 | 06:33 AM
Grzldvt's Avatar
Grzldvt
To reinforce Kevin V's comment, I have left Zaino/ZFX combination on a car for over a week before I removed it. I had absolutely no problems removing. It was the same as leaving it on for a few hours.
Old Oct 28, 2003 | 06:05 PM
BillR's Avatar
BillR
This sounds crazy, but I find that when I leave Z5 OR Z2 on over night, the shine is more wet like than if I remove it an hour or two later.
Use ZFX esp if it is below 70 in the garage. I use ZFX about 90% of the time.
Old Oct 28, 2003 | 08:33 PM
Grzldvt's Avatar
Grzldvt
BillR, that is not as crazy as you think. I have seen it myself. I have notived the shine, when using ZFX seems to be better about 12 hours later.
Old Oct 29, 2003 | 04:43 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Just make sure you don't do ZFX and leave it outside in the sun. You'll get streaks that are tough to remove. Takes a lot of buffing!
ablaine
Nov 29, 2016 10:13 AM
westpak
South East
Aug 26, 2004 01:28 PM
