orbital vs. circular polisher
Old Nov 16, 2003 | 12:15 PM
berrywoodson's Avatar
berrywoodson
Default orbital vs. circular polisher
If one was to buy one polisher would it be an orbital or circular polisher for all detailing tasks?
Old Nov 16, 2003 | 02:51 PM
Kevin Overall's Avatar
Kevin Overall
Orbital, buy the Porter Cable model 7336 at Lowes for 109.00, its all you need. Rotary (circular) builds too much heat for the novice (you may not be, I dont know) to work with.
Old Nov 16, 2003 | 03:24 PM
scottycoyote's Avatar
scottycoyote
yeah what he said......except i bought the orbital at sears for 29 bucks.....they got all the applicators and stuff too.
Old Nov 17, 2003 | 06:29 AM
Kevin Overall
I also have a 30 dollar orbital buffer, 10 inch head. But you just do not get the best out of your compounds and polishes unless you can adjust your speed, the PC has 6 speeds, hook and loop quick change pad capability, and smallers bonnet size. The 30 dollar buffers are always that I have seen one speed and do not have the serious power that the PC has.
Old Nov 17, 2003 | 09:17 AM
Vrm_Vrm's Avatar
Vrm_Vrm
The danger to any kind of electric buffer is the heat that is created can lead to paint damage. Heat can be created by using too much pressure or by using an RPM that is too high.
Don't save a few bucks only to mess up that nice pretty paint job...
Old Nov 17, 2003 | 01:29 PM
Kevin Overall
Heat will only be a factor if you are using a rotary (circular) buffer.
Since the Porter Cable mainly uses foam pads (you can use wool or cotton, but even then since the head never makes a circle, not much heat will build up) heat build up is almost zero.
Old Nov 21, 2003 | 11:54 AM
FlaPhil's Avatar
FlaPhil
Fact is, paint will get heat damage when the surface reaches about 250 degrees F. A PC will never reach that kind of temperature. If you use a circular, keep the speed around 1000 - 1500 RPM. This will not create the kind of heat required to do damage. The PC is really the best for the weekend detailer.
You should really never have a need to use wool (unless working on your boat's gel coat). Wool is like sand paper. Use it ONLY to work out deep scratches. By itself, it will apply more swirls and scratches.
Use foam for applying polishes with both the PC or circular, and remove by hand with MF towels for best results.
Old Nov 21, 2003 | 04:51 PM
Michael-Dallas's Avatar
Michael-Dallas
Oddly enough, I have a 10" Sears orbital buffer and I've been looking at the Porter Cable models recently. Lots of good info.
Thanks guys!
Michael.
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
