Niteshade overspray
Old Nov 3, 2010 | 11:48 AM
tayb350z's Avatar
tayb350z
Default Niteshade overspray
So I tinted my tails/turn signals awhile back with VHT Niteshades and I masked off everything around both lights but apparently some overspray managed to get on my rear fenders. At first it felt like the orange peel type before I clay bared it, now its smooth as the rest of the paint but you can still visually tell there is overspray on it. Would I be able to buff or maybe polish this out? Thanks for the help
Old Nov 3, 2010 | 11:56 AM
sdZ33's Avatar
sdZ33
You should have taken them off of the car before spraying them
Old Nov 3, 2010 | 12:09 PM
bmccann101's Avatar
bmccann101
worse case scenario yes, you can use WET 2000-4000 grit and actually sand ti lightly if you know what u are doing ( dont even think about it if not) and then buff it.
Sanding gets stuff off, well, like sandpaper..
buffing just cuts the clear coat and buffs it back to a shine, but buffing over somethng other than swirls doesnt really cut the substrate off the paint.
You will have to do both, one then the other.
Old Nov 30, 2010 | 11:23 AM
08sleeperz's Avatar
08sleeperz
I was in the same situation when I did my old car. I got some turtle wax rubbing compound and that took it off in less than 5 min. Just be sure to wax after u use the rubbing compound.
umsta
North West
Nov 3, 2007 11:26 AM
macao_friend
Northern California
Apr 23, 2007 05:27 PM
zand02max
Cleaning & Detailing
Jul 14, 2005 08:45 AM
taurran
Dec 4, 2004 05:24 PM
SpoonieLuv
Mar 14, 2004 08:12 AM
