Headlight Restoration
Old Jul 15, 2012 | 10:16 AM
JCITY's Avatar
JCITY
Headlight resto kits are available at most auto supply stores.You may want try these first.Macquires makes a good one
If you are not "technically proficient",suggest takong to a shop that does restoration.
You may screw up the lenses more than they already are.
Some of the oil change joints offer this.I'd be careful with these unless you have actually seen the results.
Many times if the job is not done correctly or,the lenses are beyond fixing,the "fogging"
will come back after awhile.Most procedures involve sanding the lenses.
It may bring back the clear but it also takes off the UV protection.
Sealing needs to be done.
Have you done a search on this?Pretty common problem.
Good luck
Old Jul 15, 2012 | 12:29 PM
122554's Avatar
122554
2000 grit sandpaper, wet sand, rubbing compound, wax!
Old Jul 15, 2012 | 01:02 PM
sdZ33's Avatar
sdZ33
I ALWAYS wet sand with 1500, then 2000, then 2500... after the sanding part is complete, I buff with rubbing compound, then buff with Glaze, then buff with Ultrafina, then Wax!
Yes if you wetsand the lights you are technically "removing" the "UV protection", but if it really were protected, then they shouldn't have fogged up in the first place...
Now, you said you have small cracks in the lens... Those are more than likely stress cracks wich will not be removed by the procedure above... From what a friend told me is that he removed stress cracks from his lens by starting the sanding procedure with 600 grit, but I find that hard to believe... You may opt to buy new lights(but that would cost a lot) or you can buy a set of the cheap Ebay lights and swap out the lenses...
There was a thread on here regarding HL resto, but at the end of the project, he used a clear furniture varnish of some sort that can be bought at the Homo Depot... I'm positively sure that if you would have SEARCHED, you would have came across it!
Either way, whatever you decide to do, just remember to wax your headlights... I usually do it after every car wash...
Old Jul 15, 2012 | 02:11 PM
TravisFTW's Avatar
TravisFTW
thanks. i did search and found lots of different ways that people do it ... just didnt know what the best way is. .. i've seen where people wet sand them, then clear coat and then polish them ... would this work?
Old Jul 15, 2012 | 02:28 PM
RMichael's Avatar
RMichael
Colgate toothpaste and a sponge. I'm not kidding. Now pay me what you'd pay a pro.
Old Jul 15, 2012 | 05:43 PM
Waiz's Avatar
Waiz
Threads merged for easier referencing, also there is a pretty good DIY for this:
https://my350z.com/forum/repairing-a...storation.html
Old Jul 15, 2012 | 06:30 PM
sdZ33's Avatar
sdZ33
here is the uv protection thing I was talking about...
https://my350z.com/forum/body-interi...v-coating.html
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
