Removing Dealer Branding
Old Feb 18, 2004 | 10:56 AM
z-extreme's Avatar
z-extreme
Default Removing Dealer Branding
Hey,
I want to remove the dealer Badge from my car. It's a sticker of sorts. What's the easiest way to remove without wrecking the paint.
Thanks
Old Feb 18, 2004 | 11:14 AM
mgk65's Avatar
mgk65
Heat it up a bit with a hair dryer, slowly peel off.
If there is any adhesive residue use googone or a tar remover.
Old Feb 19, 2004 | 06:09 AM
z-extreme's Avatar
z-extreme
Thanks - I'll try that
Old Feb 19, 2004 | 07:55 PM
boz's Avatar
boz
One of my friends took the emblem off his BMW with dental floss.
Old Feb 22, 2004 | 03:56 PM
johnsZ's Avatar
johnsZ
I have thought about charging the dealer for advertizing- like 50 cents per day....
If the badge is a sticker or decal, then the hair dryer will work- do not put on too much heat or the glue can end up hardening and you will have a mess. BE PATIENT. Use popsicle sticks to lift the decal- that way there is very little chance of scratching the paint- DO NOT PUSH HARD as the paint surface will be softened by the heat.
If the badge is the plastic type (molded), then you can wrap a putty knife blade with a lot of duct tape to cushion the blade and prevent scratches, and gently pry off the badge. You will be left with some residue, which should come off with simple green or the orange stuff. Use the stuff straight from the bottle, and rub really gently until the residue comes loose from the paint, then wash a couple times with water and buff up. Just be patient.
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
