Making Sure With Zaino
Old Apr 1, 2004 | 06:58 PM
lemonjihwan's Avatar
lemonjihwan
Default Making Sure With Zaino
I have PPW Z with some swirl marks.
and im about to order z2 and z5 zaino.
is that enough? or i need some more products?
Old Apr 1, 2004 | 07:16 PM
SungNamZ's Avatar
SungNamZ
If you would like to apply Z2 or Z5 and remove within minutes Vs hours, get ZFX additive. If Zaino is going to be your car care product of choice, get Z6 and Z7 also. Take at zainobros.com for a complete explanation or each of these products.
Old Apr 1, 2004 | 07:20 PM
lemonjihwan
is Zaino carwash soap better than regular meguiars carwash soap?
so basically, nothing wrong step Z5 -> Z2 right??
thanks.
Old Apr 5, 2004 | 12:38 AM
Jung918's Avatar
Jung918
i got the total protection car care it. there just ain't no better polish...
Old Apr 5, 2004 | 07:18 AM
Kevin Overall's Avatar
Kevin Overall
You have to have EITHER Z-1 or ZFX to activate the Z-2 OR the Z-5. Z-1 is used once per six months as is ZFX at a bare minimum, If I could get one or two more products it would be the Z-6 and Z-18 if you do not already have a clay bar...........
Old Apr 5, 2004 | 07:08 PM
lemonjihwan
thanks! i just ordered Z-1.
Old Apr 6, 2004 | 02:18 PM
Nappi82's Avatar
Nappi82
Thumbs up
Just put my first coat of Zaino on, and Im hooked! Took a little while to go through all the steps, but it was worth it....even if it is supposed to rain tom. Well worth the time and $
Old Apr 8, 2004 | 08:14 PM
lemonjihwan
omg! im confused again...!!!!
i just received Zaino. and read instruction.
i was wondering,
am i only using Z5 till the swirl marks to go away???
which is like after 5~6coats???
that will take me like a month!!?!?
after couple of Z5's.. can I put Z2 on same day??
Thanks
-Ji-
Old Apr 8, 2004 | 08:25 PM
MarkY's Avatar
MarkY
Zaino will NEVER get rid of swirl marks. The best it will do is hide them and it doesn't do that very well, especially on dark cars.
Your best bet would be to use a Porter Cable with some Meguires #9 or if you have real bad swirl marks get some 3M swirl mark remover.
Old Apr 8, 2004 | 10:59 PM
zcombat's Avatar
zcombat
Actually Meguiars #9 doesn't contain any abrasives but fillers. I would say use something like 3m smr or the menzerna twins to remove those imperfections.
Old Apr 10, 2004 | 09:32 AM
Kevin V's Avatar
Kevin V
If using the ZFX additive you can do 3 back to back coats in a single day. The ZFX/Z-5 combo also helps fill the swirls better. Since Zaino stacks and lasts VERY long, the more coats the less swirls you have. To me it is better than removing clearcoat to get down to the bottom of the swirls. The next major thing is to make sure that the supplies you use and your technique are not constantly putting in new swirls.
Old Apr 12, 2004 | 05:50 PM
lemonjihwan
okay.
first of all. i have to put Z1, and put Z5 like several time. right?
that will take me about 5~6 hours. and then i have to put Z2 right? but the thing is.. do i have to put Z5 before Z2 whenever im zainoing my car?
Old Apr 13, 2004 | 02:22 PM
Kevin V's Avatar
Kevin V
No you can go back and forth between Z-2 or Z-5 whenever. I mostly use nothing but Z-5 since my car is a darker color.
I'd also recommend getting the ZFX instead of the Z-1. My son can do about 3 coats in 2 hours, but he is really quick.
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
