Dr Bonz Zaino Experiment II
Old Apr 2, 2003 | 05:20 AM
  #121
CHIEF1731's Avatar
CHIEF1731
Cool
Had Zaino order form in hand and came to this link to view posts before making final decision on whether to proceed with this product or go in a different direction.
You made the decision easy. Your shine is awesome!
Old Apr 2, 2003 | 08:17 AM
  #122
aelius's Avatar
aelius
I agree that the Z6 doesn't reduce the electrostatic charge as much as I had hoped.
Last month, when the acatia trees first began to bloom, the car was covered with pollen. And the panels still pick up dust from the brakes and road.
Old Apr 2, 2003 | 12:36 PM
  #123
spf4000's Avatar
spf4000
Just to experiment I sprayed on the Z-6 on only one side of the hood, and a few days later, I saw absolutely no difference in the amount of dust on either side of the hood.
I personally feel that the only thing Z-6 is good for is to remove any remaining residue of Z-2 after a coat, and to remove the bug guts from the bumper in between washes.
Old Apr 2, 2003 | 12:40 PM
  #124
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I agree with you guys here. The Z-6 seems to make the car a little slicker, but it doesn't seem to reduce static. I have used the California Car Duster for years on both my Stealth and now on the Z and it is amazing. Just run it over the dust/pollen very gently and it comes right off. I keep mine in the back of my Z for quick dustings.
Old Apr 2, 2003 | 02:58 PM
  #125
RAW22's Avatar
RAW22
Cool
Maybe we need to grind up some Claritin into a powder and mix it with our Z6? I hear Claritin works very well when there is a high pollen count.
I just went out and used my CCD, and it worked perfect. I just wasnt sure if it would mess up my Zainoing hours.
Rich
Old Apr 14, 2003 | 07:32 AM
  #126
DUKE's Avatar
DUKE
Bonz - What do you think about all this talk about Crystal Guard?
You not thinking about trying it are you?
(I notced they are advertising on a lot of the other forums.)
Old Apr 14, 2003 | 08:22 PM
  #127
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I was sent a free sample of CG from Tako but I haven't used it yet. The weather has been cold here. Just starting to get nice. I plan on trying it on my Stealth and seeing if it lives up to the hype.
Old Apr 15, 2003 | 11:00 AM
  #128
Showcars's Avatar
Showcars
Once you have Zaino on your car, dust and pollen aren't going to stick to the finish (unlike a waxed car, where dust & pollen DO stick). The CCD is great for getting off the dust. However, the CCD out of the package is loaded with oil. The oil will suck up the dust, but some of it will deposit on your car, causing streaks and giving new dust a place to stick. I recommend soaking your CCD in a bucket of hot water with Dawn dishwashing liquid. You'll be amazed what comes out of that water (gallons or red dye). Repeat this a few times, then let your CCD dry thoroughly before using.
When my car sat in the garage for a long time, I'd hit it with the CCD, then finish with Z-6 and a towel. That took 10 minutes, and I'd leave the garage with a car that looked like it had just been polished.
Old Apr 15, 2003 | 04:15 PM
  #129
g35cfan's Avatar
g35cfan
I'm a Zaino newbie, but I'm loving it. Have 5 coats on my G coupe so far. How come you have to apply it in a linear motion? I didn't know this and was applying it in a swirling motion. Still seemed to come out alright.
Old Apr 15, 2003 | 05:44 PM
  #130
amartin's Avatar
amartin
Generally, you always want to wax/wash in straight lines... never circles because it tends to cause 'swirls', which, because you create them at every possible angle (a circle), in the sun, you will AWLAYS see swirl marks.
Its not just Zaino, its really anything that touches your car (from a chamois to wax/synthics)... should be applied in straight lines.
-- Aaron
Old Apr 15, 2003 | 07:00 PM
  #131
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Ditto on the straight line thing. Circles give you swirls if you have anything embedded in your applicator or towel.
The Cali Car Duster is covered with Parafin wax and when it's new, it does leave little streaks that easily wipe off. Mine however is now about 7 years old and is no longer red. It is gray-black and works better than ever. It no longer leaves the streaks either.
Old Apr 17, 2003 | 05:23 AM
  #132
DUKE's Avatar
DUKE
Cool, keep us informed. (And don't take any bribes. j/k)
Have you ever washed your CCD? I have had mine for 5 months and it looks dirty but works great.
I found this under the FAQ section on the http://www.calcarduster.com/ website.
Q - How do I clean my Duster?
A - Because of a special permanently baked in paraffin treatment, The Original California Dusters are made to provide years of effective service without the need for cleaning. Simply shake them out before and after each use. The "dirtier" they get the better they work.
If you find it necessary to clean your Duster because it is too dirty or if the Duster stops lifting dust, it can be washed. You may hand wash your Duster in cold water with a mild detergent such as Woolite, then air dry. Do not use hot water to wash or hot air to dry, as heat or harsh detergent may remove the special paraffin treatment.
Old Apr 17, 2003 | 08:46 AM
  #133
RAW22's Avatar
RAW22
I respectfully disagree. I have 3 coats of Zaino on, and my car is covered with pollen. I honestly do not think there is anything you can do not to get it on, except not drive it.
Thanks for the helpfull CCD info.
Richard
Old Apr 17, 2003 | 09:31 PM
  #134
RAW22's Avatar
RAW22
Because Sal says so...
RIchard
Old Jun 11, 2003 | 06:03 PM
  #135
DUKE's Avatar
DUKE
Bonz - How many coats of Zaino are you up to now?
Old Jun 12, 2003 | 04:34 AM
  #136
DUKE's Avatar
DUKE
25 (Just read your article on the other site.)
Old Jul 18, 2003 | 04:08 PM
  #137
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I am now up to 37 layers. 35 "Old School" and 2 New Formula!
New Formula Experiment
Old Apr 7, 2004 | 08:15 AM
  #138
mode101's Avatar
mode101
Originally posted by ZeeForMee
Beautiful man, just beautiful.
what he said
Old Apr 7, 2004 | 08:56 PM
  #139
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Wow, this is an old thread. I now have 55 layers and haven't put one on since Thanksgiving.
Old Apr 8, 2004 | 08:52 AM
  #140
sluggoZ's Avatar
sluggoZ
Pics.....Spectacular!!!!
