waxing stokes... method ???
Old Oct 1, 2002 | 05:28 AM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Default waxing stokes... method ???
1/ Circular or...
2/ One way -- then run the rubs perpendicular ?
2/ above sounds right.. but I have heard a lot...
Brad .. anybody.. appreciate your comments.
thanks
Old Oct 1, 2002 | 11:20 AM
Brad4rdHay's Avatar
Brad4rdHay
It really doesnt matter in a perfect world, but unforunately, ther'es gonna come the time when you are waxing, and you didn't get every last spec of dirt off, and will case minor swirls as you wax. So in this situation, its better to go with stright up and down strokes, as IF you create any marks, they will be less noticeable, as the sun will have to hit them at the right angle for them to be noticable, where as a buch of little circular swirls are noticalbe frm every angle.
Old Oct 1, 2002 | 11:51 AM
sean2168's Avatar
sean2168
He is correct, it is better to go in a straight stroke. I recommend following the angles of the car as a guide on direction. If you do get or have swirls, it's easier to just reapply wax in those areas and remove it in a back and forth motion rather than trying to rub them out with just a cloth.
Old Oct 1, 2002 | 08:41 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
When I applied the Zaino to my car I used side to side "lines" on the horizontal surfaces (roof, hood, rear hatch) and up and down lines on the vertical surfaces. I actually tried to use one solid line from one side to the other (i.e. from the splashguard behind the front wheel up over the fender flare over the hood and down the other side. It's kind of hard but I did it where I could.
Sean and Brad, Do you also need to use straight lines to REMOVE the stuff as well or are circles OK for that?
Old Oct 2, 2002 | 05:41 AM
sean2168's Avatar
sean2168
The choosen method of removing is not nearly as important as the application, but it does make some what of a difference. As a general rule I take it off the same way I put it on.
Old Oct 2, 2002 | 10:23 AM
ZZtopp's Avatar
ZZtopp
"Oh, Danielsan.......Wax on.......wax off."
Mr. Myagi
Old Oct 2, 2002 | 11:27 AM
Brad4rdHay's Avatar
Brad4rdHay
Again, the specific movement really doesnt hav ean affect on applying/removing the product, as long as its done evenly. What you want to worry about is the possability of swirls. So yes, when I remove a product, just use rapid back and forth motions. Remember, some people try to kill the finish when removing, just use enough pressure to get the residue off, no more.
Siqcology
Sep 18, 2019 01:45 PM
dcains
Sep 21, 2015 09:28 AM
Slexis200
Cleaning & Detailing
Oct 9, 2002 02:40 PM
tranZition
Oct 5, 2002 06:48 PM
Brad4rdHay
Sep 2, 2002 06:56 PM
