Zaino Q & A - All questions welcomed
Old Oct 6, 2002 | 12:23 PM
vicmar90's Avatar
vicmar90
Sean, thanks for your information. I have been using Zaino on my 350Z and I am very happy with it. My question is that I ran out of the Z-6 Gloss Enhancer and in the interim am using the Meguiar Quick Detail in-between and after car washes. I am in the process of ordering more of the Z-6, however, in the meantime is there a major difference between these two products?
Thanks.
Victor
Old Oct 6, 2002 | 02:04 PM
Brad4rdHay's Avatar
Brad4rdHay
The only differnece is that the Zaino has polymers in it that are suposed to enhance the durability (i find only slightly).
If you want to save some money, buy a gallon of Meguiar's Final Inspection (the "Quick Detailer" has silicons in it). Final Inspection is a very slipery, expendable QD spray.
Old Oct 6, 2002 | 02:14 PM
vicmar90's Avatar
vicmar90
Thanks Brad.
Victor
Old Oct 9, 2002 | 04:59 PM
MacGuru's Avatar
MacGuru
ok, I was hoping that someone could clarify proper application. Do you apply in a circular motion or in a north/south direction? I've read both on the posts, and I'm still not sure which is the correct way to apply. Any help? -m
Old Oct 9, 2002 | 07:40 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Not circular. Side to side. Up and down on vertical surfaces and right to left (or left to right) on horizontal surfaces.
Old Oct 11, 2002 | 12:16 PM
MacGuru's Avatar
MacGuru
Thanks Doc. I'm picking up my Zaino products tomorrow. Since it's raining here in ny, I won't be working on it until early next week. I'll post picks once I've finished. Hopefully all will go smooth. Cheers. -m
Old Oct 17, 2002 | 08:56 AM
mcduck's Avatar
mcduck
How long does it take for Zaino Bros. to turn around an order? My Brickyard Z will arrive in the next 2-3 weeks and I plan to send my Zaino products order in this weekend. Will it be here when my car arrives?
With any luck, I'll be able to reproduce the good Dr.'s fine work.
Old Oct 17, 2002 | 11:48 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
mcduck: They are usually pretty fast. If you have seen their website, you need to print their order sheet and fill it out and mail in with a CHECK (no credit card orders unfortunately), and mine came in about a week after I mailed it in. I am in western PA and they are in Jersey. It would be longer to west coast or deep south I would assume.
Old Oct 19, 2002 | 08:23 AM
drivebywire's Avatar
drivebywire
I am kinda confused about Zaino. Could any one please help this first timer what zaino I should buy and what sequence I should apply?
1. Z1
2. Z2
3. Z3
4. Z4??
thanks in advance.
Old Oct 25, 2002 | 10:10 AM
gfunk808's Avatar
gfunk808
what is the URL for the zanio website??
Old Oct 25, 2002 | 01:14 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Zaino Website Here!
Old Oct 25, 2002 | 02:39 PM
gfunk808's Avatar
gfunk808
okay, cool, thanks!
(these guys have to figure out how to get onto yahoo's search engine)
Old Oct 26, 2002 | 06:12 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
There have been several threads posted with complete protocols for buying/applying Zaino. Try doing a search of thread titles on this forum using the search word ZAINO.
Just a quicky though. The bare bones basics you'll need are the Z2, Z5 and the Z6 (ZFX is nice also to make it cure faster but it's pricey). Good luck.
Old Oct 26, 2002 | 09:06 AM
gfunk808's Avatar
gfunk808
here's zanio's instructions:
ZAINO APPLICATION TIPS
1. Because Zaino Show Car Polish is optically perfect (99.9%) The
optimum results are achieved by using over wax free paint.
2. If you are looking for the ultimate paint surface preparation. Use
Zaino Z-18 ClayBar first or skip to Step 3.
Zaino Z-18 ClayBay was designed to remove airborne contaminants,
paint overspray, water spots, rail dust, industrial fallout, diesel fuel
& catalytic converter residue and any other bonded surface contaminants
from paint. All cars even brand new factory paint has airborne
contaminants... Here's the deal. The non-abrasive Z-18 ClayBar will
remove
any surface contaminants from the paint finish and not hurt the
clear-coat. The ClayBar will get that paint finish smooth as glass. Now
remember waterspots, bird droppings and bug guts if left on the
paint finish for any length of time. Will etch into the paint finish.
The ClayBar will also remove any store bought waxes....
I recommend you use my car wash (Z-7) as a lubricant for the ClayBar.
Just make sure to keep the surface area lubricated while using the
ClayBar.
Use 1/2 capful of Z-7 Car Wash to 12 ounces of water. I use a spray
bottle
for the mix. Shake it up and spray the area to be Clayed. Just make sure
to keep the surface area lubricated while using the ClayBar.
3. I would definitely recommend you remove the wax buildup on your
paint. Just use Liquid Dawn(hand dishwashing liquid) as a car wash. It
has a high alkaline content which cuts right thru carnauba wax,
paraffin, silicone oils, etc. This will get your paint finish squeeky
clean and wax free.
I don't advise making a habit of washing your car with Dawn. But for
this scenario it's fine. High alkaline products like Dawn are tough on
polishes. It will never harm the paint finish though. A car wash is made
specifically to clean without removing durable polishes. ALSO, Make sure
you remove any water spots, before you apply my products. Because Zaino
has no abrasives or harsh solvents it will not remove water spots or
stains. Z-18 ClayBar is great for removing any paint surface
contaminants.
Re-wash the entire vehicle with Z-7 Car Wash immediately after the
ClayBar
Cleaning Process.
4. The basic products you will need are Z-1 or the new ZFX, Z-2,
Z-5(optional, but highly
recommended for swirls and especially on darker colors), Z-6 and Z-7.
If you are going to use the NEW ZFX flash cure system, then skip step 5
and read the ZFX
instructions below..
5. Start with Z-1 Polish Lok as per directions. Z-1 does not need to
dry. Remember do not wipe off the Z-1 Polish Lok. Apply Z-5 or Z-2
directly over the Z-1. Z-5 is the Hot ticket for a swirl free, flawless
paint finish. Usually one to three coats will accomplish that.
6. Let Z-5 or Z-2 polish dry at least one hour. Please NOTE: Zaino Show
Car Polish works best at 60 degrees or higher. However, it can be
applied down to temperatures of 45 degrees. It just will take much, much
longer to dry. As much as two to three hours drying time is required if
the temperature is 50 degrees or below. Also, If the humidity is high.
Longer drying time is necessary. Humidity is a killer on the drying time
of Z-2 or Z-5. The moisture in the air hinders drying
time up to four times longer than normal. Sorry, but I can't help this.
When you try to remove Z-2 or Z-5 when it is still wet. All you're
accomplishing is moving it around. Kinda like reapplying it. Also you
need to use a LARGE White 100% Bath size towel (please refer to my Tips
& Tricks sheet on my web site for the proper towels to use) to remove
Z-2 or Z-5. Smaller towels will not work efficiently.
To test if Z-2 or Z-5 is dry and ready to be removed. Wipe your finger
on a hazed section. It should immediately come off and leave a crytal
clear finish. If it smears, it is still wet. You can leave Z-2 or Z-5 on
for hours or overnight if you desire. When it is not humid Z-2 will take
anywhere from 30 to 60 minutes to dry. Depending on how heavy you
applied it. I have applied Z-2 in the Arizona sun and it dried in
approx. 3 to 5 minutes. I have also applied it in 38 degree temperature
and it took about 2 to 3 hours to dry. Be patient. It's worth it.
Different situations affect drying times. Also, remember you have Z-1
and Z-5 both on the car. That is two products that have to dry at one
time. Takes longer. Z-2 or Z-5 does not contain any oils and once it's
dry will never ever look smeary or feel greasy. If you remove Z-2 or Z-5
before it is thoroughly dry and get any smears. Just wipe down the car
with a damp cotton towel. This will remove any smears. Don't use Z-6
until you wipe the car down. If you'd like call me and I'll help you out
with more info!
7. After removal of Zaino Z-2 or Z-5. You should wait 24 hours if the
outside temperature is under 70 degrees and 6 hours if over 70 degrees,
before applying the next coat of Z-5 or Z-2.
8. Use Z-6 "Gloss Enhancer" spray as per directions, between each and
every coat of Z-5 or Z-2. It really helps give a three dimensional look.
It's antistatic properties will reduce dust and dirt pickup by 60%. Z-6
can be used immediately after removing Z-2 or Z-5 or right before
applying the next coat of Z-2 or Z-5. Most of my customers prefer to use
Z-6 both, before and after Z-2 or Z-5 for that extra gloss boost.
9. You can switch to Z-2 as soon as you are happy with the way the paint
finish looks. Example, no more swirls, scratches etc. It's up to you.
Z-2 has higher optical properties than Z-5. You can go from Z-2 to Z-5
and then back to Z-2 as often as you want. Z-2 and Z-5 are 100%
compatible and interchangeable. You should always end with Z-2 as the
last coat because of its higher optics.
10. The number of coats of Z-2 or Z-5 is up to you. When you reach the
level of enhancement you like, normal maintenence with Z-7 Car Wash and
Z-6 "Gloss Enhancer" spray is all that's necessary. Naturally apply a
coat of Z-2 or Z-5 whenever you feel it is required.
NOTE: One application of Zaino Z-2 or Z-5 will outlast anything in the
industry and is all you'll ever need for an average vehicle. However,
Multiple coats will achieve an even deeper, wetter-looking, ultra high
gloss. Plus higher paint protection. It's up to you....You be the
judge...
ALWAYS use only 100% Cotton towels. They must be Made in USA. Brand name
(Cannon or Fieldcrest) large white bath size towels. See my web site,
for the real truth on cotton towels and which ones to use.
ZFX™ Instructions
When used as directed, Zaino Bros' ZFX™ Show Car Polish accelerator
enables Zaino Show Car Polish to cure instantly and increases
durability. This exclusive product allows you to create a “Show Car
Finish” in a day and gives your car months of lasting protection.
This kit contains a 2ml vial of ZFX™ Show Car Polish accelerator mix and
four mixing bottles. The vial contains enough ZFX™ to prepare 16 ounces
of polish.
Pour one to two ounces of Show Car Polish (Z-2, Z-3 or Z-5) into a 2
ounce ZFX mixing bottle. For each ounce of polish, add 4 to 5 drops of
ZFX™ (no more than 10 drops for two full ounces), screw the cap back on,
and shake vigorously for 60 to 90 seconds.
ZFX™ enabled polish must be applied to a clean car. Follow these easy
steps:
1. Apply Zaino Show Car Polish enabled with ZFX™ with a 100% terry cloth
applicator. Use the polish sparingly. A small amount goes a long way,
and you will be applying multiple coats.
2. Squirt a dime size dab of polish on your applicator and rub it into
your paint using back and forth hand motions.
3. Allow the polish the haze (dry) for 30 minutes.
4. Buff off the Show Car Polish residue with a high quality, 100% cotton
detailing towel.
You're now ready to apply your next coat of Zaino Show Car Polish
enabled with ZFX™. There's no need to wait. Simply follow steps 1
through 4 again. Use a fresh buffing towel with each coat. Apply no
more than three coats of Zaino Show Car Polish enabled with ZFX™ in a 24
hour period. fro optimum results use enable ZFX withing 6 hours of
mixing
When you are finished polishing, wash mixing bottle inside and out with
a heavy concentration of liquid dishwashing detergen and rinse
thoroughlyt. The ZFX™ mixing bottles cannot be reused if the polish
remains in the bottle for more than 12 hours. After 12 hours, it is not
possible to remove the ZFX™ accelerator from the mixing bottles. Throw
the mixing bottle and any unused polish contents away after 12 hours.
Old Oct 27, 2002 | 08:20 AM
ares's Avatar
ares
Veteran
bah, you dont have to sell me, I already own it and use it. my question is simple.
is it safe to wax a new car?
bought the car yesterday, and told the dealer not to wax it(it had been waxed once) but I figured, no reason for them to possibly cause swirl marks on my paint so I can remove it later and put zaino on.
so anyway, can I do it immedietly, or wait a month or 2?
Old Oct 27, 2002 | 07:31 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It can be done immediately. You may want to use the claybar first though. Even though the car is new, it will still have dirt and contaminants on it. Take a look at my thread titled Dr. Bonz Zaino experiment II. In it you'll see a pic of the claybar after I used it on the brand new Z (had it four days).
Old Oct 27, 2002 | 08:10 PM
ares's Avatar
ares
Veteran
HA just try to stop me from using the clay bar. That things great, and I know its getting spotlessly clean with it.
Old Oct 30, 2002 | 07:18 AM
  #38
geeZer's Avatar
geeZer
It sure is pricey!
You get 2ml for $19.95 which comes out to $37,754.00 a gallon.
(One gallon is 3785.41ml)
You wouldn't need it most of the time, except for being in a real hurry or in weather conditions described on the Zaino site.
Old Nov 1, 2002 | 07:04 PM
  #39
kj301's Avatar
kj301
Default Z1
I am a first time Zaino user. When i sent in my order form I forgot to order the Z1. Do i really need the Z1 or can i place a coat of Z5 then Z2 down. What are the drawback to not using Z1? I would like to start using the polish this weekend, but I will wait for Z1 if needed.
Thanks,
KJ
Old Nov 1, 2002 | 07:14 PM
  #40
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
If you got the ZFX you don't need the Z-1.
