Pressure Washer
Old Oct 26, 2002 | 10:21 AM
bighamz's Avatar
bighamz
Default Pressure Washer
OK to use? Honestly don't know either way...
Figured if I got one I could hit the car twice a week to make major cleaning less of a chore.
Old Oct 26, 2002 | 11:03 AM
Stone Z's Avatar
Stone Z
Exclamation
Absolutely not....period.
Old Oct 26, 2002 | 11:32 AM
Brad4rdHay's Avatar
Brad4rdHay
Thumbs down
Old Oct 29, 2002 | 11:45 AM
WashUJon's Avatar
WashUJon
What's the reasoning on not using it? Will it blast contaminants into the clearcoat or something?
Old Oct 29, 2002 | 05:29 PM
Bazazu's Avatar
Bazazu
Default My Thoughts
Its a good idea in theory - I mean really, water is supposed to be the cleanest substance etc, and you'd have a touchless carwash, which should be Ideal.
However remember that water has many minerals, using the pressure washer is going to really imbed those into your clearcoat good and haze it up (give it the old faded look)
Also, if you go from an angle, any dirt that you have will be "pushed" by a very high power stream of water. When your washing with a pressure washer its not like the water immediatly gets under the dirt and it never touches the car again, your gonna press it against the car with the force of the water, for at least a short distance until it gets washed away.
Personally whenever I wash my cars I use a hose and just put my thumb over it, or I'll whip out the spray nozzle and "mist" the car. I never use a direct jet on the car though.
Old Oct 29, 2002 | 06:22 PM
rouxeny's Avatar
rouxeny
You know those car wash bays where you drop in some quarters for 3 minutes of water? Are those considered high pressure. Of course, if you actually squeeze the handle, it gets to be be pretty high, but what if you just let it flow without squeezing down? The water comes out pressurized, but I don't think it's too high.
Hope I'm right.
Old Oct 29, 2002 | 08:04 PM
ares's Avatar
ares
Veteran
if I could do it, I would only do it with deionized water.
other than that, a high powered system from close up could probably make creases in the metal, and carelessly blow emblems off the car if not careful...
maybe a rinse and just do it from 2 feet away so it becomes more of a mist than a solid stream.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
