Drag NHRA, IDRC, IHRA, NDRA
Drag Wheels/Tires For Track Model
Old Jan 3, 2005 | 02:34 PM
mjedens's Avatar
mjedens
Default Drag Wheels/Tires For Track Model
Thought I'd mention in the "Drag Racing" section that I'm selling 2 16" Weld Wheels and MT ET's that will fit over Brembo Brakes. See the Classified Section.
Old Jan 5, 2005 | 07:07 PM
done12many2's Avatar
done12many2
How much? Please PM me as soon as you can. Sounds like what I have been looking for.
Old Jan 6, 2005 | 01:57 AM
mjedens's Avatar
mjedens
Sold !
Old Feb 8, 2005 | 02:24 PM
mrtomcat's Avatar
mrtomcat
can you post the dimensions please since I'm looking at this as well
Old Feb 9, 2005 | 01:53 AM
mjedens's Avatar
mjedens
Default dimensions?
The following is my personal experience trying to "drag" the track model. If you keep the "Brembo" brakes, the smallest wheel you can go with is a 16" Weld Prostar XP (8.5" wide). With this wheel I used a MT ET 26 by 11.5 tire. Before that I tried a 18" BFG Drag Radial on the Track wheel and I wasn't satisfied. I mentioned earlier that Weld does not make the 16" Prostar anymore so good luck on finding a pair. I've personnally swapped out the Brembos for the stock brakes now and gone with 15" Weld's, slicks and skinnys!!
Old Feb 13, 2005 | 08:46 PM
mrtomcat's Avatar
mrtomcat
I got the 18's BFG right now and not happy either.
I'm thinking of going the slicks route as well, do you think there are any dangers of breaking the axles with Slicks?
Old Feb 14, 2005 | 02:43 AM
mjedens's Avatar
mjedens
Default mrtomcat
I broke the drivers side half axle on a pair of MT ET Streets but my air pressure was down to 6 and I was using a 200 plus shot off the line. (It should break doing the above) I now have after market half axles from driveshaftshop.com and use the correct air pressure (12 to 15) on a pair of 15" MT Slicks.
Old Feb 14, 2005 | 10:16 AM
mrtomcat's Avatar
mrtomcat
good info, thanks
Old Feb 14, 2005 | 04:48 PM
nitrous350's Avatar
nitrous350
Thanks all Good Info
But what is offset on the 15" wheel I need ......
cause My 15x8.5 wheel and 26x11.5x15 ET Street rubbing bad....
So what is collect Offset on 15" wheel
EnjukuRacing
Sep 30, 2015 06:55 AM
