Drag NHRA, IDRC, IHRA, NDRA
first time racing the Z...
Old Jan 13, 2005 | 08:37 PM
mrtomcat's Avatar
mrtomcat
Default first time racing the Z...
so I went to Irwindale (1/8 mile) tonight with my new 350Z Track.
I've only raced front wheel drives before so this was my first time on a rear wheel drive.
I went bone stock including the spare. I lowered the tire pressure to 25 psi and left the stop light fuse in but turned off VDC
Burnout went actually pretty well even though I left the fuse in
I did 3 runs:
first run I launched at 4000 rpm
2.1.89--- 60' foot
6.139-- 330' foot
9.385--- 1/8
76.62--- MPH
Second run I launched at 4500 rpm:
2.268 ---60' foot
6.232-- 330' foot
9.477--- 1/8
76.61--- mph
third run the car performed like hell...see below
Now the damn shiftlight is worth nothing I could hardly see it and I kept hitting the limiter also whenever I shifted into 2nd the tires spun hard (do you guys feather into 2nd? )
I'm happy with my launches
but the shiffting I got to get down, the clutch engagement is just very different from the celica that I'm used to
Now here's the really annoying part:
the tire pressure sensor triggers an alert, I think if the pressure is below 28 psi. This shrill beeping that keeps on repeating...very distracting and I'm not sure but I think it limited the power of the car dramatically on the third run. Once I upped the pressure again it went away after about 5 minutes driving.
Is there a way to disable this stupid alert? I'm getting DR's next week on the stock rims though, is there a way to just disconnect that sensor and would that elimanate the warning?
Overall it was a lot of fun and with dr's a better shift light and shiftpoint practise I should be doing pretty well soon.
I'm also getting the technosquare reflash once they re-release it hopefully in early feb and then n2o after the first maintenance...
Old Jan 26, 2005 | 06:05 PM
weslutes's Avatar
weslutes
I like that track. Not too far away,and good practice for launching.I'd like to see what I can do with my n2o there.
Hey, I know you like the maximizer & all but I have an extra Zex kit for cheap if your interested.
Old Jan 26, 2005 | 07:15 PM
mrtomcat's Avatar
mrtomcat
thanks but I already have my NX kit from my Celi, just adding the maximizer once I put it on the Z
It would be cool to see somce more z's there. This year so far I've been the only one
Old Jan 27, 2005 | 06:17 AM
VeeTec's Avatar
VeeTec
I get my best results running the stock pressure, and launching at 3K.
I also loose traction going into 2nd, but you have to shift quick for best results.
My best 1/8th so far has been an 8.89 stock.
Old Jan 27, 2005 | 06:19 AM
VeeTec's Avatar
VeeTec
I should add that I set my shift light for 6,900, and shift right as the light comes on.
Old Feb 2, 2005 | 10:48 AM
DSGMach714's Avatar
DSGMach714
Hmmm, does that MPH seem a bit low? I would have figured maybe 79-80? I've been to Irwindale with my Mach, and would average about 84 MPH trap. I was hoping my brand new 350 would at least hit 80..
Old Feb 2, 2005 | 12:01 PM
mrtomcat's Avatar
mrtomcat
the best MPH I hit so far is 78
Old Feb 2, 2005 | 01:56 PM
zpeed350's Avatar
zpeed350
With a 2.1 60' I would think your 1/8 would be way better. I don't know how much traction your losing in 2nd.
I granny shift every gear (clutch/gas - clutch/gas), and like VeeTec, I shift very fast into second. They break for a second and then catch. And then keep shifting as fast as I can.
I drop my pressure down to 25 psi and warm up the stock tires pretty good.
My best run:
60' - 2.236 ( workin on it)
1/8 - 9.007 @ 80.82
1/4 - 13.796 @ 103.91
That's a crappy 60' with a sweet ET and MPH. So with your better 60' foot time you should be able to run faster. Are you at sea level?
Old Feb 2, 2005 | 03:05 PM
mrtomcat's Avatar
mrtomcat
I'm still bad at hitting the right shift point, I keep on shifting a bit too early. I'm going back tomorrow and expect another improvement
but yes I seem to slip quite a bit in 2nd and then catch again
Old Feb 2, 2005 | 07:54 PM
bhk1004's Avatar
bhk1004
i ran a 8.9 1/8 at 79 with a 2.1 0-60 in my auto
Old Feb 2, 2005 | 08:16 PM
mrtomcat's Avatar
mrtomcat
but not stock was it?
Old Feb 2, 2005 | 09:58 PM
bhk1004's Avatar
bhk1004
just test pipes and CAI
Old Feb 2, 2005 | 11:01 PM
FLZ_Boy's Avatar
FLZ_Boy
I'm interested in knowing how you do in Irwindale. In addition, let me know if quickshifting into 2nd and hiting WOT is better or partial/feathering into 2nd would work better.
Old Feb 2, 2005 | 11:13 PM
mrtomcat's Avatar
mrtomcat
that should do it allright
Old Feb 2, 2005 | 11:15 PM
mrtomcat's Avatar
mrtomcat
I'll keep posting my improvements, last few weeks irwindale has been horrible, last week I got in 2 runs within 3 hours...every second car kept on breaking down. I hope it'll be better tomorrow.
Old Feb 8, 2005 | 01:53 PM
RBlover69's Avatar
RBlover69
what i need is a vid or detailed instructions how to launch the base model man, i spin tremdously if i launched at 2k, also, being that im new to the rwd platform, (used to fwd), ...when you launch the Z , do you rev while in gear then drop the clutch or stay in nutrual then mash it into first while reved at 2K ?????? i know know ,but i had to ask. I have to make sure im launching this car properly
Old Feb 8, 2005 | 02:15 PM
mrtomcat's Avatar
mrtomcat
I know the feeling coming from fwd...I kicked booty on fwd launches
so far I have to say that feathering is the trick. I used to be able to rev to 7k and then drop the clutch and take off on the celi. On the Z you have to baby it or you spin out. I still have hella wheel spin whenever I get into 2nd, might have to feather there as well
Old Feb 8, 2005 | 02:54 PM
RBlover69's Avatar
RBlover69
thanks, ...mr, do you leave it in gear while rveing or mash it in first, while reving
Old Feb 8, 2005 | 09:43 PM
mrtomcat's Avatar
mrtomcat
always leave it in gear otherwise it takes to much time
Obadabot
Jun 18, 2023 11:31 PM
