Drag Radial Wheel Size
What is a good setup to run? Can I run 18" up front and 16" for drag radials in the rear. I don't know how the different wheel sizes effects everything. Some help please...
Originally posted by fowlman01
If I see you 1/5 we can talk about it Sean.
I've never tried fitting the z32 rear wheels on a track model so i can't say for sure. Ideally you'll get the smallest diameter wheel that will fit as the tire you'll go with will have more flex in the sidewall which will give you better bite off the line.
Just buy a set of weld racing wheels for the back. Pick up some 15s and street ETs. You will regret going with DRs down the road becuase you will eventually wanna just get street ETs. Ive heard this from countless other poeple at the track.
Originally posted by done12many2
My friend is currently using 15 inch wheels on the rears with ET Streets. He has no problem clearing the brakes on his, however they will not fit on my car due to the Track model brakes.
if you go with a 15x8, you will need 5.5" backspace. If you go 15x10, you will need a 6.5" backspace... both wheels come out to about a 25mm offset... and obvioulsy a 5x4.5 bolt pattern...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
