Drag NHRA, IDRC, IHRA, NDRA
New Stock Block APS RECORD 11.67
Old Apr 25, 2005 | 01:01 PM
  #41
Z ELIMINATOR's Avatar
Z ELIMINATOR
Did you have to change the wheel studs with the rims and the spacer? If you changed the studs did the stock lug nuts fit ? My other rims are the RO JA 5. 19 x 10 . with the custom lug nuts.
Old Apr 25, 2005 | 04:50 PM
  #42
one3502nv's Avatar
one3502nv
I just replied to your PM... But to answer this question.. I am also running 19x10 Roja formula 5's as well as my race wheels with the stock studs.... I do not use spacers on any of my wheel setups.... Not really a good idea... As far as race wheels, you will need shank style lug nuts....
Old May 25, 2005 | 01:34 PM
  #43
mrtomcat's Avatar
mrtomcat
Originally Posted by Alberto
I once drove up on some e.t. streets, only about 30 miles though. Speeds as high as 70 mph on the way there. I set the tire pressure to 20 psi for the drive up. What shocked me the most was how much they "float", just driving 50 mph in 4th and giving it gas sends the a$$ into a wiggle, you are always correcting when driving on slicks. Its almost like driving on a flat tire, if you stay on the gas, its easier to control than if you vary your speed. If you dont want to drive up on them just have a freind take your slicks and a jack up for you, thats what I did last time I went to the track.
damn I was hoping they would go a bit smoother...
What's the tire pressure you set it up at the track?
Old May 25, 2005 | 01:59 PM
  #44
one3502nv's Avatar
one3502nv
I run my MT ET Streets at about 16lbs.... Depends on weather and track conditions...
Old May 25, 2005 | 06:08 PM
  #45
mrtomcat's Avatar
mrtomcat
how about lug nuts what type do I need? jegs has several listed
Old May 25, 2005 | 08:43 PM
  #46
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
You need 12x1.25mm spline type lugs....when I called JEGs they only had 4 of them..so I called summit racing and they had them in stock...just tell them you need 12x1.25mm lug nuts for weld ProStar wheels...and they'll know exactly what to send you...
Old May 25, 2005 | 09:25 PM
  #47
mrtomcat's Avatar
mrtomcat
Thank You!
Old May 26, 2005 | 09:02 PM
  #48
mrtomcat's Avatar
mrtomcat
Ordered a set of prostar's and MT's today....now if my APS kit would finally arrive...
Old May 27, 2005 | 02:43 AM
  #49
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I ordered my APS kit in MARCH...and it's still not here...
Old May 27, 2005 | 12:39 PM
  #50
mrtomcat's Avatar
mrtomcat
I'm so eager to finally get the turbo I'm jumping up and down....but the wait is killing me
Hey I forgot to ask: Do I need Spacers for the Wheels?
Old May 27, 2005 | 06:03 PM
  #51
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Where did you order your APS kit from??
No spacers required...plug and play
Old May 27, 2005 | 09:24 PM
  #52
mrtomcat's Avatar
mrtomcat
I am part of the group buy that took place on here in the FI forum
Old May 27, 2005 | 10:28 PM
  #53
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Be ready to wait a LONG TIME...
sherm
Apr 11, 2020 05:21 PM
