Drag NHRA, IDRC, IHRA, NDRA
Goin to the strip for the first time, single turbo built motor 350z
Old Mar 21, 2006 | 07:59 AM
If you are familiar with road racing, then you know that safety is important. Watch a few cars before jumping in line. Where is the return road? Is there one or two? Which side?
The only tricky time that I have is when the humidity is 80 percent plus and the surface is slippery. First gear is no big deal because you expect wheel spin. At times wheel spin in second gear surprises me, and I end up with the car pointed at the wall.
If I had to concentrate on on particular area it would be 60-foot times. Experienced street racers often go to the track for the first time and run 2.2 second 60-foot times, then are disappointed because their ET is 14.0 seconds plus.
Be safe. Have fun.
Old Mar 21, 2006 | 09:12 AM
Ep3's Avatar
Ep3
well i know is there is a yellow/green m3 in FL Bad @ss looking car that ran 11.98 his name is jmweb thats who wants to run you so bad?? also as far as i know he is the only e46M3 to brake 12's
Old Mar 21, 2006 | 09:20 AM
southern_info's Avatar
southern_info
Make sure you get some footage of ya'll running the strip. Good Luck!
Old Mar 21, 2006 | 10:25 AM
gnxs's Avatar
gnxs
Originally Posted by Ep3
.....also as far as i know he is the only e46M3 to brake 12's
Not true.
Old Mar 21, 2006 | 12:08 PM
Ep3's Avatar
Ep3
^ i dont mean brake into 12's i mean into 11's maby there are pro cars running faster im just going off what ive seen on e46psi.com they said he was teh first
Old Mar 21, 2006 | 03:33 PM
Fairlady_z33's Avatar
Fairlady_z33
hey 350zbiturbo what r the final numbers
Old Mar 22, 2006 | 04:32 PM
350zbiturbo's Avatar
350zbiturbo
never got to put high numbers, the car started getting to hot on the dyno, after we were done tuning low boost, and now i have a freakin problem with this stupid kit that the pipe that comes from the intercooler to the turbo, is coming off b/c the stupid clamp turbonetics supplied that connects the pipe to the turbo on the driver side is too big so it keeps popping off after a high load on the car, and im seriously getting sick after 2 days of having the car back ive had to jack up the car, take off my wheel, open the fender well and fix the pipe, and put it all back together what a pain in the **** seriously, theirs just something that turbonetics took for granted that really **** me off sometimes.
Old Mar 22, 2006 | 04:45 PM
Fairlady_z33
tell them to replace it it came from them like that so its their duty to supply the correct equipment
Old Mar 22, 2006 | 04:53 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Does your pipe come off at a certain boost range? If it is coming off before 10psi then the pipe/coupling/clamp isnt aligned correctly. I had some issues as well(pass side IC charge pipe to charge pipe that goes up to intake pipe-coupling needed to be like 1" longer to make it easier to adjust), but they had sent the wrong clamps so I tried some clamps that didnit hold bosst, with the correct clamps problem solved....
Old Mar 22, 2006 | 07:56 PM
Fairlady_z33
Hey 350zbiturbo send me a PM with your number so i can know where you guys are meeting on friday to go up their let me know.
Old Mar 22, 2006 | 09:05 PM
98intrigue's Avatar
98intrigue
Please post videos! I really want to see what the TN kit can do.
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
fst100
North East
Sep 8, 2015 11:37 AM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
