Drag NHRA, IDRC, IHRA, NDRA
Inexpensive drag wheel and radial set up.
Old Sep 18, 2008 | 01:00 PM
  #61
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
Originally Posted by Nexx
how much for 2?
PM sent!
-Dan
Old Sep 18, 2008 | 02:52 PM
  #62
wannabuy350z's Avatar
wannabuy350z
Originally Posted by WheelDude.com
Rota still produces this size and we have it available. The exact wheel specs are as follows
SLIPSTREAM 1580 e40 5X114.3 73 FBLK
These wheels are very light and the 15x8 model is only 14 lbs The wheels will be pretty tucked on a Z though.
-Dan
will they fit over brembo's? if so, how much shipped to 92124. for 2.
what other drag set-up do you have?
Old Sep 19, 2008 | 06:25 PM
  #63
skaterbasist's Avatar
skaterbasist
I doubt you're going down the track at 150. Which means your tire pressure is too low.
There's a saying in drag racing. I think it goes something like "you haven't drag raced until you do the slick dance going down buck fifty."
What would be the ideal pressure for these MT ET's? I'm not forced induction.
Old Sep 19, 2008 | 10:10 PM
  #64
VeeTec's Avatar
VeeTec
16 lbs.
Old Sep 20, 2008 | 11:39 AM
  #65
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
It depends on the weight of your car and what the conditions of your track and climate are.
For slicks, you want to be at the highest possible tire pressure without slipping. So, you always start high then reduce it by 1 psi if you spin. When you hook up without spin, that's where you want it to stay for that night.
Old Sep 20, 2008 | 12:42 PM
  #66
skaterbasist
Thank you. I usually stick around 15 PSI.
From the research I did, it seems as if the "floating" & swaying I have during the last portion of the track is normal.
Old Sep 20, 2008 | 01:28 PM
  #67
3hree5ive0ero
Retired Admin
You shouldn't be swaying too much. If you are, then you need more air in your tires. You should feel very little, unless you're going 115+.
Old Jan 6, 2009 | 12:08 PM
  #68
medstudent25's Avatar
medstudent25
subscribing...
HoBrahYouStink
Jun 24, 2016 10:58 PM
