Drag NHRA, IDRC, IHRA, NDRA
proper way to warm up the street tires
Old May 4, 2006 | 09:22 PM
Z33FairLady_Z's Avatar
Z33FairLady_Z
Default proper way to warm up the street tires
can someone tell me the proper way to warm up or "clean off" my stock tires for drag? never done it before.... thanks
Old May 4, 2006 | 10:40 PM
Blue_Streek's Avatar
Blue_Streek
take the traction control off, and just give some good gas in first. you really do NOT need to heat up street tires. the stock 040s tend to get gummy if they get too hot. so just a good quick once around should do the job. where you gonna race? LACR, Irwindale, Perris of Qualcomms parking lot?
tommy
Old May 4, 2006 | 11:15 PM
Acree's Avatar
Acree
I usually just feather the clutch out in first at around 4k rpm. Spin them for about 2-3 seconds, just enough to clean them off. Street tires SHOULD NOT be warmed up.
-Acree
Old May 5, 2006 | 12:35 AM
Z33FairLady_Z
tommy
do i drop the clutch and floor the gas? btw im going to lacr
Old May 5, 2006 | 12:37 AM
Z33FairLady_Z
-Acree
can u explain in steps?
Old May 5, 2006 | 12:46 AM
Acree's Avatar
Acree
1. Go around the water.
2. Hold the revs at 4k.
3. Don't drop the clutch, but smoothly let it out in under 1/2 a second or so.
4. Hold the revs around 6200 to 6500 rpm for 2-3 seconds.
5. Push the clutch in and let off the gas at the same time.
The idea is to make the tires spin to get rid of any debris. Don't worry about rolling foward while doing this, because you will definitely roll forward. But don't hold it for too long. Without using the brakes, if you are rolling past ANY of the staging lines, its too long.
-Acree
Old May 5, 2006 | 12:56 AM
taurran's Avatar
taurran
Drive through the water box and do a HUGE BURNOUT!
Old May 5, 2006 | 01:17 AM
roast's Avatar
roast
+1
Old May 5, 2006 | 02:12 AM
Acree's Avatar
Acree
Hah Taurran you are not helping!
-Acree
Old May 5, 2006 | 03:03 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
just make sure you go AROUND the water please. that is the key. the just rev it up to about 4 grand and drop the clutch. let the tires spin for about one second with street tires. it is just enough to spin any dirt or rocks off them and maybe a little bit of water the people before you might have drug up outta the box...
Old May 5, 2006 | 07:35 AM
Z33FairLady_Z
so drop the clutch or no? i got two different answers here
Old May 5, 2006 | 07:38 AM
tommy
+1. Street tires are designed not to get hot. Don't play Ricky Drag Racer in the water box.
Old May 5, 2006 | 07:40 AM
dirtroad's Avatar
dirtroad
pretend you are a smiley and do the following steps:
seriously, you'll get a feel for it after your legs stop shaking... the first time is very nerve racking, and my legs still get shaky from the adrenaline rush.
Old May 5, 2006 | 07:42 AM
Z33FairLady_Z
so dont even warm it up at all?
Old May 5, 2006 | 08:50 PM
Armitage's Avatar
Armitage
No, don't warm them up. Just clean them a bit if you feel the need.
I think most people feel launching around 2k RPM's is the best for a tractable start.
Old May 6, 2006 | 02:57 AM
dlt1cy's Avatar
dlt1cy
what do you do when you have no choice but to drive through the box? some places are set up that you cannot go around.
Old May 6, 2006 | 03:15 AM
Audible Mayhem
My350z
then i would probably do a little bit of a burnout to make sure the water was heated up enough to come off the tires. i would rather take the chances of them being too hot and not as sticky than wet at all...
ablaine
Nov 29, 2016 10:13 AM
