Drag NHRA, IDRC, IHRA, NDRA
First trip to the track..
Old Aug 9, 2006 | 09:04 PM
myturbo350z's Avatar
myturbo350z
Default First trip to the track..
well my 03 touring is bone stock, and when i got to the track i saw about 3 other zs there, none of them breaking into even 14s. so i went up for my first run, **** nervous, spun through first gear, 16.3xx at 99mph, i was so disappointed in my first run, so i staged again. messed up even worse, ran 16.7xx. boy was i bumming out. then my last run before the track closed, i pulled it together and ran what i thought was awesome for my first time at the track (left lane)
Old Aug 9, 2006 | 09:26 PM
Mewantbfp's Avatar
Mewantbfp
i think that says 14.089 for the 1/4 mile if so then nice job good to see you didnt leave dissapointed.
Old Aug 9, 2006 | 11:34 PM
myturbo350z
yeah it was good :-)
Old Aug 9, 2006 | 11:46 PM
Cannysage's Avatar
Cannysage
I can't see jack
Old Aug 9, 2006 | 11:56 PM
myturbo350z
Here is a better pic
Old Aug 10, 2006 | 12:15 AM
roast's Avatar
roast
there we go...
Not too shabby for your first time out in a stock car.
Did you have your spare? Did you adjust tire pressure? How much gas? What was the weather like? 90ft elevation(lucky dog).
Old Aug 10, 2006 | 06:07 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice job for your first time out, best of all, HUGE improvement in only 3 runs....
Old Aug 10, 2006 | 06:50 AM
bboypuertoroc's Avatar
bboypuertoroc
Nice job on you're first time out.
Old Aug 10, 2006 | 10:42 AM
14.0 seconds is a good job. When the weather is cooler in September, take a helmet. You will be running 13.99 seconds or better.
Old Aug 10, 2006 | 12:02 PM
BluZee's Avatar
BluZee
You'll be in real good shape with a 2.0 60ft.
Old Aug 10, 2006 | 12:17 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'm so jealous of all the people living in the northern states..
Good times for your first time out and definitely a big improvement on your 3rd run from your first two.
Old Aug 10, 2006 | 12:46 PM
myturbo350z
i did not have my spare, i didnt adjust the tire pressure, which i should have, no idea how much gas i had cause my gauge is broken haha, and it was the perfect weather, 64 degrees.
thank you everyone.
Old Aug 10, 2006 | 12:49 PM
myturbo350z
it was so hard to launch though
Old Aug 10, 2006 | 01:20 PM
And to add, with a respectable 60-foot time you will be running better than 13.90 seconds.
Old Aug 10, 2006 | 02:29 PM
BluZee's Avatar
BluZee
Yeah, just like I said four posts up.
Messin with ya.
Old Aug 10, 2006 | 10:57 PM
myturbo350z
thanks, im going to try and work on my 60 foots next time i go. Launchin is what messed me up, my buddy who owns a high 11 sec srt-4 was telling me i was moving good after i hit 2nd gear. what technique do you guys use to launch? what rpm? do you just dump it, or ride it out a bit?
Old Aug 11, 2006 | 06:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You need to find a good balance of wheelspin and traction. Every car/track/event will be different but what worked for me stock was the following...
27psi in rear tires, and a very quick slip - or slow drop, how ever you want to look at it, out of the hole at about 2500-3000rpm's. This gave me 2.0 60ft's and enabled me to run 13.77 and 13.80 stock. Even with a mid 2.1 60ft you should be 13.9's your very close....Good luck.
Old Aug 11, 2006 | 07:23 PM
bacalhau16's Avatar
bacalhau16
I cant lauch lower then 3000rpms or I bog. I usually try to launch at about 3500 rpm. I have yet to see how effective this is for me at the track though. Im gonna try it out real soon though.
Old Aug 11, 2006 | 09:15 PM
misfit's Avatar
misfit
2500 to 3000 is ideal for stock with a slow drop "dont side-step". 2.1 60' with some wheelspin netted me a 101 trap with 32 PSI and everything in the car.
Old Aug 11, 2006 | 10:51 PM
3hree5ive0ero
Retired Admin
That's because you're just dumping the clutch. You shouldn't bog down. Feather it a little.
In fact, go to a nearby drag strip and try it out and you'll learn.
