Drag NHRA, IDRC, IHRA, NDRA
75whp increase...trap speed to expect ?
Old Aug 15, 2006 | 04:33 PM
booger's Avatar
booger
Default 75whp increase...trap speed to expect ?
I was at 350whp and trapped 108mph with a 2.0 60ft [ street tires ] . Ive added 75whp , what can I expect my traps to be now ?
Old Aug 15, 2006 | 04:41 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
you mean 250 whp and trapped 108 right? cuz if you had 350 whp and only trapped 108, you should just give me your car..
Old Aug 15, 2006 | 04:44 PM
Malic350's Avatar
Malic350
+1
Old Aug 15, 2006 | 04:45 PM
3hree5ive0ero
Retired Admin
No, E.. I called dibs first
Old Aug 15, 2006 | 04:47 PM
cracka350z's Avatar
cracka350z
*punches 3hree5ive0ero in the nuts* now im first!
Old Aug 15, 2006 | 04:49 PM
booger's Avatar
booger
Im not a good driver and I have a G35 [3700lb's] with AT5 . Yes 350whp Vortech on a Mustang dyno...NO correction to DynoJet numbers . I now have 425 whp on the same dyno...local track has closed and no where to find out for my self
Old Aug 15, 2006 | 04:53 PM
roast's Avatar
roast
114?
Old Aug 15, 2006 | 04:54 PM
3hree5ive0ero
Retired Admin
Well, thank you booger for admitting you're not the best driver in the world like most people on here. If you only got 108 with 350whp, it tells me you've had lots of traction issues. Maybe you shouldn't have upped the power but rather worked on your traction issues.
As for your question, I would assume somewhere around 110 due to traction issues.
Do you have a timeslip you can post so we can see what's giving you a hard time on the track?
Old Aug 15, 2006 | 04:59 PM
booger's Avatar
booger
You come up to Nebraska in the middle of a corn field and run your Z . You would be lucky to break into the 13's at all . Ive seen a bunch of Z's run before the track shut down and none of the broke into the 13's .You guys get spoiled at good tracks that are at or close to sea level , and probably a down hill track . Ours was a old runway .
Old Aug 15, 2006 | 05:03 PM
booger's Avatar
booger
No , no time slips . Its been over a year since Ive been there . I ran...2.0 60ft...13 to 13.2 1/4 mile and trapped 108mph . I have gotten lucky one time and got the 60ft to 1.98 and ran 12.98 at 108mph . Ive always tried to keep the gas on just enough to be barely spinning the tires off the line and increased gas as speed increased
Old Aug 15, 2006 | 05:11 PM
3hree5ive0ero
Retired Admin
Trust me. You need to come to TX and race in the extreme heat and humidity. The car will not run even close to what you'll expect. I drag in 100 degree weather with 50% humidity. That's why my personal best doesn't look like much and that's why we dyno so low.
Old Aug 15, 2006 | 05:14 PM
booger's Avatar
booger
Well what times and trap speeds do you get . I take it you are mostly stock ? You have to remember Im probably 500lb's heavier also .
Do you run DR's - slicks ?
suspention set up for dragging ?
Nealoc187's Avatar
Nealoc187
Given the same atmospheric conditions at the same track, probably about 5mph.
Old Aug 15, 2006 | 05:17 PM
booger's Avatar
booger
We have the same weather , Maybe higher humidity in the corn field ..lol
Old Aug 15, 2006 | 05:18 PM
booger's Avatar
booger
Thanks...just wanted to get an idea on what it would be .
Old Aug 15, 2006 | 05:22 PM
roast's Avatar
roast
That's pretty much what I said. If you want an even better idea, run it and see.
Old Aug 15, 2006 | 05:25 PM
booger's Avatar
booger
Wish I could . Like I said, track closed and we only have a 1/8th mile now
Old Aug 15, 2006 | 05:32 PM
Malic350's Avatar
Malic350
lol - gotcha
Old Aug 15, 2006 | 05:33 PM
roast's Avatar
roast
Just guessing with your old numbers you possibly ran the 1/8 in 86-87mph.
So trap 91-92mph.
Old Aug 15, 2006 | 05:34 PM
3hree5ive0ero
Retired Admin
I'm basically stock - popcharger, mrev2, y-pipe back exhaust.. I only dyno'd at 244 whp and 230 wtq.. it was 101 degrees though with high humidity..
My best was a 13.8 @ 103 with a 60' of 2.0. This run was on 23rd of June so imagine all the heat and humidity of Texas during summer.
