Drag NHRA, IDRC, IHRA, NDRA
NEW PB: 11.53@121mph
Old Oct 29, 2006 | 12:09 PM
  #101
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by 1fish
WOW 3.1 seconds, thats enzo territory!! simply amazing, And i do agree with your desire not to change the car permantly for dragin it would ruin a perfectly good car , but still air bags are made just for that reason, and dont affect the cars performance in anyway when there deflated, , your wise to be cautious on the psi side personaly 15 is about as far as i will drop my tires, I worry too much about spinning the tire off the rim and having a serious accident at top end. I still think you should consider a drive shaft loop I hate to hear about you pogo-ing at 120+
Good luck and good racing, Matt.
The driveshaft is carbon fiber, so it would shatter if it did break. it does basically have a driveshaft loop. The stock sub frame connector halfway between the trans and the rear diff loops under the driveshaft so if it did break that coupled with the exhaust right under it would make it very tough for the driveshaft to go anywhere.
Old Oct 29, 2006 | 04:40 PM
  #102
diwun67's Avatar
diwun67
Originally Posted by BriGuyMax
Oh and the whole 0-60 thing, if you calculate my 0-60 based on my 1/4 mile pass, it's around 3.1 seconds. Not too shabby with a shift involved.
3.1 is awesome, but how did you calculate that?
Old Oct 29, 2006 | 04:57 PM
  #103
1fish's Avatar
1fish
Yea i took a look under there and it seems like the subframe connector would keep if from falling forward, its not the drive shaft the loop is ment to protect its the universal joints if the front one goes on an unprotected car and the shaft falls and catches on the track the car is launched , kind of like a pogo stick, hence the term pogo-ing.
Old Oct 29, 2006 | 05:08 PM
  #104
bacalhau16's Avatar
bacalhau16
That is a really awesome time Briguy! Your car is quite the "sleeper" I must say, and is very clean. It seems as though you would like to become one of the premier drivers here on my350z. As is you werent already up there as it is. Good stuff, and good luck with your new setup whatever it is you decide.
Old Oct 29, 2006 | 06:09 PM
  #105
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
http://www.wallaceracing.com/0-60_equation.php
one of the many on the internet...accurate to within +/- two tenths
I just plugged my new numbers into that and it spit out 2.9 seconds
So on the worst side of things my car goes 3.1-3.2 0-60...still pretty decent.
Old Oct 29, 2006 | 06:12 PM
  #106
diwun67's Avatar
diwun67
Interesting!!
Old Oct 30, 2006 | 08:31 AM
  #107
gnxs's Avatar
gnxs
I've used that before, but your post just reminded me to plug in my new best timelip. Comes out to 2.25 seconds 0-60 with the ET Streets on.
Old Oct 30, 2006 | 09:57 AM
  #108
scotts300's Avatar
scotts300
My g-tech registered a 2.85s 0-60 for my car. My numbers input to that site calculated a 2.62s 0-60. Just a little data to share.
MardiGrasMax
Tuning
Jun 9, 2009 03:20 PM
eagletanggreen
Drag
30
Oct 1, 2007 06:43 PM
Kenk2
Tuning
Mar 17, 2007 08:22 PM
Nic@CiNcity
Tuning
Dec 27, 2006 05:20 AM
Road Warrior
Tuning
130
Dec 7, 2006 06:33 AM
