Drag NHRA, IDRC, IHRA, NDRA
Line Loc worth it??
Old Oct 23, 2006 | 05:50 PM
rwalton1129's Avatar
rwalton1129
Default Line Loc worth it??
Hey what do you guys think about using a line loc for burnouts. I hardly ever do them but when I do dont you think it would be worth not f***in up your back brakes.
-Ryan
Old Oct 23, 2006 | 05:54 PM
glowz825's Avatar
glowz825
Not worth it.......unless you have a drag car. I for one would not be doing too many burnouts--you will break something expensive eventually
Old Oct 23, 2006 | 05:56 PM
If you own a serious drag racer, you would know the answer.
Old Oct 23, 2006 | 06:06 PM
JisNis's Avatar
JisNis
He doesnt own a "Serious" drag racer, thats why he's asking. I too would like to know.
Old Oct 23, 2006 | 06:22 PM
350Zteve's Avatar
350Zteve
-Ryan
They work great. Had one in my Supra and loved it. Only costs like $80 and you can install it yourself if you know what you're doing.
Old Oct 23, 2006 | 07:10 PM
You may be able to adapt a kit such as this. I am not certain how the ABS-VDC-TCS system will react to locking the front brakes. For street tires it is overkill. For drag racing and slicks it is a good idea.
Old Oct 24, 2006 | 10:18 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I was going to install line locks on my car, but during my most recent trip the the strip last weekend I figured out how to consistantly do long smokey burnouts with the brake fuse pulled. No line locks for me.
Old Oct 24, 2006 | 11:21 PM
JisNis's Avatar
JisNis
This is a dumb question but how do you go about doing your burnouts? Do you leave it in first or shift into second? I havent tried the brake fuse trick yet and Im having a hard time heating up my DRs. Any info would help. Thanks.
Old Oct 25, 2006 | 07:06 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Pull the stop lamp fuse by the dead pedal. Get your rears into the water. Start in second gear, tach it up, dump the clutch and quickly get your left foot on the brake.
Old Oct 25, 2006 | 09:51 AM
mrtomcat's Avatar
mrtomcat
I used to pull the fuse, actually built a little switch that I can turn it on and off but it will wear on your brakes and you will still have fishtailing issues.
On top of it you can use them for launching which is something you can't do with just the brake fuse pulled
I got Line locks installed over a year ago and love them, never leave home without them
you need 2 of them and they have to be installed after the TCS/VDC to not trip the computer
here's the link to what I have....again you need to buy 2 of them
http://www.jegs.com/webapp/wcs/store...tegoryId=26861
Old Oct 25, 2006 | 10:02 AM
JisNis's Avatar
JisNis
Mrtomcat where did you have them installed? Or did you install them yourself? Easy?
Old Oct 25, 2006 | 10:06 AM
mrtomcat's Avatar
mrtomcat
I had them installed at Brainstorm back then.
It took about 3 hours, biggest part of the job is flaring the brake lines
here's a pic:
Old Oct 25, 2006 | 04:10 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
line locks are way to go if you dont like holding the brake at just the right spot while doing a burnout, i have noticed that these brakes are kinda touchy and push them too hard, the car will bog, push them not enough and the car will start to move forward. i dont have any problem doing a burnout with them, the important part is to make sure you get the tires really wet...
good luck either way...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
