Drag NHRA, IDRC, IHRA, NDRA
Dragging 5AT
Old Oct 26, 2006 | 11:10 AM
BluZee's Avatar
BluZee
Originally Posted by ZLadie2000
How do you do a burn out in auto mode?
Step on the brake and stomp on the gas.
Old Oct 26, 2006 | 01:11 PM
cj350's Avatar
cj350
How do you do a burn out in auto mode? Also, are pulleys worth it in the 5AT?
Step on the brakes and hit the gas peddle and than release the brakes very slowly till about when the cars rear tires are a bit free from the brake hold and the fronts wheels are still locked. This should help. Also you do not need to burn out on street tires and also (Burn Out = really spoiling your tranny)...... I screwed my tranny up once. ...LOL
Old Oct 26, 2006 | 03:38 PM
Thumbs up
Originally Posted by BluZee
Heres a damn time slip! Its the best I could do at 3,000 ft elevation.
Damn good 60-foot time. Nice work.
Old Oct 26, 2006 | 03:44 PM
Originally Posted by bigo109
Here's a few tips: 1/4 tank gas, 36 psi all tires(works for me), stop lamp fuse pulled(for burnouts), tcs off, spare tire & tools removed, small burnout in auto mode(just to clean the tires off), brake launch 2500rpm's, hit the gas on the 3rd amber light, manual mode shift at red line. Anyway that's what works for me, practice and find out what works for you! I'll be adding a pro- torque converter & sgp valve body soon. Here's my time slips and a video I made. Good luck!
http://videos.streetfire.net/video/9...23000567c1.htm
I see very few automatic 350Zs running better than 14.00 seconds. Nice numbers.
Old Oct 26, 2006 | 03:59 PM
garyovich's Avatar
garyovich
could you please elaborate on removing the stop lamp fuse, i don't get it.
gary
Old Oct 26, 2006 | 05:59 PM
doc10374's Avatar
doc10374
The fuse in automatics cuts 20% power at a heavy load....launching. So, by removing the fuse, at your launch you will be taking off at 100% as opposed to 80%. That's info I've read as well as a few others however, I have not really noticed a difference on the time slips.
Old Oct 26, 2006 | 07:29 PM
BluZee's Avatar
BluZee
Thanks. That was the one and only time I ever pulled a 2.0 60ft.
Im getting too much wheel spin now to do it again.
Old Oct 27, 2006 | 05:42 AM
bigo109's Avatar
bigo109
Thanks. After the tranny upgrades, I should be even faster.
Old Oct 27, 2006 | 09:14 AM
bigo109's Avatar
bigo109
gary
The stop lamp fuse has a safety feature that cuts power when it senses that the brake and gas are being pressed at the same time. You need to remove this fuse to be able to do burnouts and brake launchs. Removing the fuse gives you full power. Just remember to put the fuse back in before you leave the track or you won't have any tail lights on the way home. I hope this helps!
Old Oct 27, 2006 | 09:18 AM
garyovich's Avatar
garyovich
thanks for the response, much appreciated
Gary
Old Oct 27, 2006 | 09:54 AM
BluZee's Avatar
BluZee
Some tracks require you to have working taillights when running at night time though. I know mine does.
Old Oct 27, 2006 | 10:26 AM
ZLadie2000's Avatar
ZLadie2000
Where is the fuse located?
Thanks.
Old Oct 27, 2006 | 10:36 AM
Just one is OK.
Old Oct 27, 2006 | 10:50 AM
BluZee's Avatar
BluZee
Just one is OK.
Yeah, thats true.
Old Oct 27, 2006 | 11:10 AM
Jime's Avatar
Jime
Yeah, thats true.
The rule is usually tail light too not brake light, I always disconnect my brake lights when bracket racing so no one can tell what I am doing at the end.
dlt1cy's Avatar
dlt1cy
I'll throw in my two cents.
1) Pull the plug near the master cylinder. (allows power braking keeping brake lights, but disables abs, speedo, odo)
2) Heat street tires. (more than a quick spin, but less than a slick and avoid the water box if possible. I have always been told not to heat them, but that is bull.)
Old Oct 27, 2006 | 11:32 AM
bigo109's Avatar
bigo109
Thanks.
It's in the fuse panel on the driver's side. When you take the panel off, look at the diagram on the back and it will show you where the "stop lamp" fuse is. I think it's the 4th one on the bottom row from the top, but check the chart to make sure.
Old Oct 27, 2006 | 11:34 AM
  #38
doc10374's Avatar
doc10374
The fuse panel on the driver's side down by your feet.....happy spinning!
Old Oct 27, 2006 | 11:59 AM
  #39
BluZee's Avatar
BluZee
So when you take out the brake fuse does it disable the brake lights or both the brake lights and tail lights?
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
praxis
Feb 15, 2005 04:51 AM
