Drag NHRA, IDRC, IHRA, NDRA
5AT on Spray
Old Oct 27, 2006 | 08:20 PM
doc10374's Avatar
doc10374
Default 5AT on Spray
Well, I feel pleased with the results considering the following factors. I do not have bottle heaters and the pressure was at 875(a little low)Outside temp was 62; I'm thinking I was not getting the full 100 shot. Plus I ran on my 19" heavy a$$ tires but here are my times......Having trouble figuring out the scanner.....lol
60ft - 2.08
330ft - 5.63
1/8 - 8.50@86.44
1000 - 10.95
1/4 - 13.04@109.76
Old Oct 28, 2006 | 09:14 AM
350orevo's Avatar
350orevo
nice job doc, hearing you and solidsnake go back and forth is making me want to get nitrous or FI.
Old Oct 28, 2006 | 09:16 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Invest in a bottle heater man...12's next time
Old Oct 28, 2006 | 10:12 AM
95snoozer's Avatar
95snoozer
is this at sar?
Want to run sometimes? for fun
I work on houston street right of i10
Old Oct 28, 2006 | 01:43 PM
jackie chan's Avatar
jackie chan
drag radials, bottle heater. are you not spraying until 2nd or what?
Old Oct 28, 2006 | 01:47 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
pm me if you would like to know where to get a good deal on a NX bottle heater, you are definitely not getting 100 shot if your pressure was 875.
you could be in the 12s with better traction for sure....
Old Oct 28, 2006 | 06:39 PM
doc10374's Avatar
doc10374
This was at SAR.....The temp was 62 degrees and I don't have bottles heaters so the pressure was low....grrrr. I ran a 13.04 with 19" wheels, no tune and borderline bottle pressure. The last run, to hit 13 sec, I learned to spray in 1st....this was my first time at the track with notrous. Today, I hit the spray on a back road with the pressure at 1,000psi and I lost traction in 2nd gear. This leads me to believe that with full pressure(bottle heaters for this time of year), drag radials and a reflash/tune, I will be in the low 12's easily....right?
Old Oct 28, 2006 | 06:42 PM
Brick-Z's Avatar
Brick-Z
Definetly get the bottle heater to get out of the 13's.
Old Oct 30, 2006 | 10:16 AM
95snoozer's Avatar
95snoozer
I have some 16 inch nitto DRs on some light 16s that you can use to bust off a mid high 12
I do work like 15 minutes from SAR and its on my way home to san marcos every day.
Old Oct 30, 2006 | 04:41 PM
95snoozer's Avatar
95snoozer
not sellin them, just loaning them one texan to another ;0
If you eat off every last bit of tread thast fine. I am going to be getting 315 nittos for my 10.5 inch wheels anyways to daily drive on. My car is worthless on street tires, I got the car inspected today and told the mechanic to get on it. He did a 1-2 and then left a cloud of white tiresmoke all the way down the street in 2nd gear.
Old Oct 31, 2006 | 11:13 AM
ZLadie2000's Avatar
ZLadie2000
I will be running a 100shot on my 5AT once I get my new wheels and utec installed. My goal is 12.5...
Old Nov 16, 2006 | 05:08 PM
Blububble's Avatar
Blububble
Let me tell you where to get the bottle heater. Walmart. For $10 you can get a heating pad. works great since my orig bottle heater died. takes a little while to heat up a cold bottle, but works well.
wrap the pad around the bottle and secure it with tiewraps, belts, whatever you got. yeah, i'm cheap.
Old Nov 16, 2006 | 06:20 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wal-Mart heater isnt bad, just keep an eye on the pressure so it doesnt go to high, better than the torch on the side of the bottle to bring up the pressure.
Old Nov 16, 2006 | 06:26 PM
doc10374's Avatar
doc10374
thanks for the info guys but.......I was out of town in NY and while I was gone my house was burglarized.......the bottles are gone!!!!!!!!!!!!!!!!!!!!
Doc
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
roadmax
Sep 12, 2015 05:55 PM
