Stock clutch sucks!!!!
I know that this isn't totally the right fourm but I wanted to see what clutch kits are you guys useing and how you like them. I just got back from the track and mine stuck so bad it the pedal took 5-6 sec to come back up. Gotta love an 11sec 1/8mile run. I'm running drag radials and can't launch over 4000rpms with out this happening so it's time for a new kit.
BTW I'm running a 100shot and was thinking about using an ACT kit since i'm a dealer for them and have had good luck on other cars.
Originally Posted by Steve-O Z33
100 shot, radials and 11s in the 1/8. Something definitely sounds off.
No no thats not normal the clutch stuck and never let lose thats why the time. I was running without nitrous tonight 8.90s before it started sticking on the third run. I thought about trying a higher rpm and slipping the clutch a bit might get a better 60ft. Anyways off the line I just blew the tires off hit the rev limiter then when I tried to short shift my pedal went down but never came back up till after a few sec. The sad part is I still won against a civic..
yeah, and JWT uses a stock nissan clutch
stock clutch is great to me, why would it be sticking? is that an issue with the clutch design or is there actually a defect possibly? I've dragged my car alot and never had the clutch pedal stick down, what causes this?
but I am getting a ACT flywheel along with the exedy clutch that comes in the car.
i have the JWT flywheel, but I have the Z32 TT ACT clutch...the JWT flywheel has the bolt pattern for both and the Z32 TT clutch is a little bigger than the Z33 clutch. I'm holding 430 lbs of torque just fine.
what year is your Z? I've been running 390-400whp and around 400 ft-lbs daily on my Z for 20k miles, with almost 60k on the car, all on the stock clutch, without a slip......mind you the 03's have a beefier clutch stock (well, the PP has stronger clamping force)
Originally Posted by Audible Mayhem
wow, i am starting to think that driving styles really are leading to broken parts...
my stock clutch never slipped. 150 shot on slicks dumping it at 6000.
