Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Oct 1, 2010 | 07:11 PM
  #2401
350zhr's Avatar
350zhr
07 base model, 6 spd, with vlsd, cat back exhaust and K&N drop ins. On street tires.
Old Oct 2, 2010 | 02:29 AM
  #2402
andre12031948's Avatar
andre12031948
street tires, at that track 13.4=very well done. DR 1/10 to 2/10s - different track 1/10 to 2/10s. Before the season ends, why don't you get tires & try another track.
Old Oct 2, 2010 | 09:53 AM
  #2403
03threefiftyz's Avatar
03threefiftyz
Top 25 Bolt-on HR list has been updated:
Added:
11. 350zhr -------------------------07 Base 6spd 13.418@104.99mph 2.078 60ft Verified Street
Dropped:
25. Skorch -------------------------07 Enth 6spd 13.792@102.79mph 2.098 60ft Verified Street
Old Oct 2, 2010 | 11:50 AM
  #2404
03threefiftyz
Hey Zim, I removed the pics in your above post.....Andre wanted to remove them. Just an FYI.
Old Oct 2, 2010 | 03:01 PM
  #2405
Lakeside's Avatar
Lakeside
^^^ Not a problem! He had asked me to upload some pics and post them for him in here. He needed help/wasn't sure how to do it.
Old Oct 9, 2010 | 10:20 AM
  #2406
MM'08_350Z's Avatar
Wassup!!! Fellow Z owners. I'm my way to San Antonio Raceway to Midnight Madness!!! I'm gonna test out my Mickey Thompson ET Streets on my N/A HR.. I'll be sure to post up some times and vids...
Old Oct 9, 2010 | 04:22 PM
  #2407
03threefiftyz
^Well.....how'd it go?
Old Oct 9, 2010 | 08:17 PM
  #2408
MM'08_350Z's Avatar
I'm in the staging lanes right now but my first run was 13.5 at 105 2nd run was 13.2 @ 104 and 3rd 13.0 @ 105 I'm Hoping to get into the 12s I'm crossing my fingers!!!
Old Oct 9, 2010 | 08:19 PM
  #2409
03threefiftyz
Post up your best time slip and I will update the list some time tomorrow.
Old Oct 9, 2010 | 09:06 PM
  #2410
MM'08_350Z's Avatar
My clutch gave out and was grinding in 2nd everytime... I would like to know from all you experts- Can my quaife LSD be giving out? Cuz there is a burning smell from my rear end, take in mind I also have DSS 1200 hp rated Axles...
Old Oct 10, 2010 | 08:45 AM
  #2411
MM'08_350Z's Avatar
I really hope my problem is gonna be my CM FX300 Clutch and not my tranny. But that is my best time.
Old Oct 10, 2010 | 09:55 AM
  #2412
andre12031948
I'm sorry you have a mechanical situation. Hate to see one drag racer down-temporarily I'm sure. Your time is real good, & your 60' is very good. I've been working on traction. Can you tell me what tires your using. Can you share what mods you've got?
Thanks,
Andre
Old Oct 10, 2010 | 10:02 AM
  #2413
andre12031948
You have an 08 like I do. I had slave cylinder problems that ruined my clutch at 10k-smelled awfull. Dealer (under warranty) installed new slave cylinder. I paid for clutch & flywheel
Old Oct 10, 2010 | 02:09 PM
  #2414
MM'08_350Z's Avatar
What clutch and flywheel you using? I am using the clutchmasters FX300 with the stock flywheel and it started grinding in 2nd which clutch and fly would you recommend?
Old Oct 10, 2010 | 02:26 PM
  #2415
03threefiftyz
Updated Bolt-on HR list:
Added:
4. MM'08 350Z ----------------------08 Base 6spd 13.039@105.39mph 1.789 60ft Verified slicks
Dropped:
25. JR350z08 -----------------------08 Base 6spd 13.757@102.85mph 2.176 60ft Verifeid Street
Old Oct 10, 2010 | 03:01 PM
  #2416
andre12031948
Default Hi
I'll gladly help a racer(so few) as long as you don't beat my record
Sometimes less is better-I replaced my stock clutch with one from ACT & their performance organic street disc. Its great. Works as smooth as a stock one with more confidant feel & better wear. Don't know the number, but its easy to find, called heavy duty street.
As far as your 2nd. gear. Did you miss 2nd. once or twice? If you did then maybe you pulled the shifter straight down. I've learned that its best to pull down but toward you/down pulling in. Any new top name aluminum wheel would be fine.
good luck
Old Oct 10, 2010 | 03:07 PM
  #2417
andre12031948
Now, did you use the Hoosiers or M/T & size. Do you have 4.08 gears?
And congratulation
Old Oct 10, 2010 | 03:19 PM
  #2418
Pat Bateman's Avatar
Pat Bateman
Interested in MM's mods as well
Old Oct 10, 2010 | 03:22 PM
  #2419
MM'08_350Z's Avatar
And congratulation
Thanx andre, my tires were Mickeys ET Streets 27x10.5x15 on 15" Bogart D10s and D10 front runners with Et fronts. And yes I have 4.08s. But my friends in the stand said that while I was heating up the tires one of the tires would stay still while heating up and would continue to spin when I would let off the brake.
Old Oct 10, 2010 | 03:30 PM
  #2420
andre12031948
You have a base model. Base don't have CVTS old name posi-traction. I think if you get both wheels turning you'll beat my time. I only have 2 bolt ons. & don't have 4.08s
Thats alot of tire in the rear. Are the fronts those narrow ones. My front have 235-45-17 wider than stock. If you beat me, I'll have to spend some more money
