Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Oct 29, 2012 | 10:08 AM
  #3041
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Just want to specify that taller overall diameter of rear wheels lower your gear ratio, not bigger wheels.
Old Oct 29, 2012 | 10:14 AM
  #3042
Bmurray350z's Avatar
Bmurray350z
Okay so stock wheel/tire is:
225/45/18 18x8 et30
245/45/18 18x8.5 et33
new wheel/tire will be:
245/40/18 18x9.5 et20 21lbs
275/40/18 18x10.5 et20 23 lbs
kinda confused because the last two posts kind of contradict one another.. clarify please.
Old Oct 29, 2012 | 10:17 AM
  #3043
andre12031948's Avatar
andre12031948
That's better,
but how about bigger/longer diameter & circumfererence of wheel with tire lowers your gear ratio
Old Oct 29, 2012 | 10:23 AM
  #3044
andre12031948
225/45/18 18x8 et30
That looks fine. I'm sure 3hree5iveOero will agree..
Old Oct 29, 2012 | 10:24 AM
  #3045
Bmurray350z
Okay well the overall diameter of the stock front wheels are 25.97, while the new wheels with tires would be 25.71. so it went down in diameter there.
rear stock tires are 26.68 and new wheels would be 26.66
so they went down on all four corners. am i understanding this correctly?
Old Oct 29, 2012 | 10:36 AM
  #3046
3hree5ive0ero
Retired Admin
It's the overall diameter of the wheel and tire (of course, just one of either wouldn't make sense which is why I left out "tires" in my above post) in the rear that affects your gear ratio. There was no contradiction. I was simply clarifying his "bigger wheels" as that wasn't specific enough.
Going up or down by small increments will have no appreciable effects. Once the 2 ends start to diverge away ~3% or more (ex. fronts bigger with rear smaller or vice versa) is when you start having problems with VDC and ABS. If you change both ends by equal or similar (still within 3%) amounts, then you won't have any problem and only the gear ratio is affected.
Logically speaking, differences in the tenths and hundredths of an inch in the overall rear diameter with regards to gear ratio is going to be negligible in real life. Think about it: that's like comparing new tires vs old tires.
Old Oct 29, 2012 | 10:51 AM
  #3047
redline06's Avatar
redline06
Originally Posted by andre12031948
Hey, you're getting too close for comfort. Just kidding, I'm waiting for rains & high himidity to stop one day. I'm targeting for times under 12.5 sometimes in Nov.
Haha I hope ill be visiting your times soon. By then youll be farther ahead so no worries. I think I could run 12.7 the way it sits now hopefully better eventually by cutting better than a 1.9 60'. I would like a tune but have a hard time trusting tuners around my area :/
Old Oct 29, 2012 | 10:55 AM
  #3048
3hree5ive0ero
Retired Admin
I think we're all rooting for Andre to break into the low 12s.
Old Oct 29, 2012 | 11:11 AM
  #3049
redline06's Avatar
redline06
I just looked at the top 25 not stock HR list and realized im still not updated to the list could someone do that for me? im amazed at the 109-111 trap speed thats pretty serious for a bolt on 3.5 liter V6
Old Oct 29, 2012 | 11:14 AM
  #3050
3hree5ive0ero
Retired Admin
I would but I'm on mobile right now.
Old Oct 29, 2012 | 11:24 AM
  #3051
2bad240's Avatar
2bad240
I'm shooting for 2nd place bolt on de this weekend.
Old Oct 29, 2012 | 01:07 PM
  #3052
andre12031948
Thank you but low 12's is not possible right now.
The car was totaled/flooded & it still has the original tune from 2009. I did 12.7's at the Niss./Inf. meet on a sunny but not ideal weather conditions. On a cool real good weather day, I could have done 12.6's, 12.5? maybe. I recently went to 4:08 gears & a slight adjustment to my stock suspension. I'm hoping to do 1.60's 60 foot & breaking 12.5. I think 12.4's would make me very happy. Anything better I would need some h.P. producing mods Does the saying "can't squeeze water out of a rock" fit here?
Old Oct 29, 2012 | 01:24 PM
  #3053
denchan350gt's Avatar
denchan350gt
2008 6MT Base w/ oem vlsd installed. Full bolt ons with tune (292/264), energy suspension diff bushing, gt spec subframe brace, tanabe springs.. otherwise suspension is stock.
How many runs do you get at TNT? Granted I have a auto I can pull 1.9-2.0 60ft on my 255/40/18 on rays V1 consistently.
Log your runs with different changes ie shift points, launch rpm, tire pressure to compare what is best for your setup. Which tanabe springs do you have DF or GF?
Old Oct 29, 2012 | 01:30 PM
  #3054
Bmurray350z
at TNT? whats that, lol? they're the gf210 springs. and yeah thats basically what i was doing yesterday, just testing the waters on everything, shift point, what rpm to launch at, etc.. i didnt change my tire pressure at all, 35psi. i was heating up my tires though.
Old Oct 29, 2012 | 01:46 PM
  #3055
denchan350gt
Sorry Test N Tune. Your problem is your springs which are made for grip they are too stiff.
They preventing your car from squating when you launch. Also lower your tire PSI to 30 and work your way down no lower than 25.
Drive around the water box and do quick 3-5 sec burnout up to the line. No need for a john force burnout on street tires it makes them greasy.
What track do you go and what days is it open? I have to work in hickory next week and I may drive my G and stop in Burlington on my way back.
Old Oct 29, 2012 | 02:09 PM
  #3056
NightShade's Avatar
NightShade
Originally Posted by denchan350gt
Nice!! I take it cecil was empty. I went the night before only 4 cars running when I got there at 9. Got tired of waiting at capitol.
We are planning a track day there on nov 17th TNT come on out if you can.
Oh yeah it was empty. Probably got about twenty runs in from 12pm to 4pm, which included me taking a break for food, stopping in between runs, and one car leaking fluid up and down the track that needed to be cleaned up.
Can't make it the 17th. I'm gonna try and go in December before it closes though.
Old Oct 29, 2012 | 02:41 PM
  #3057
Bmurray350z
yeah i was going around the water box, and doing exactly that. its piedmont dragway in julian, nc. they have test n tune thursday nights, and sundays at noon. let me know if you do man.
Old Oct 29, 2012 | 04:17 PM
  #3058
redline06's Avatar
redline06
Okay i just read the first 5 words and my heart sank lol just making sure , that was not today right?
Talking about the totaled/flooded part lol
Old Oct 29, 2012 | 04:41 PM
  #3059
andre12031948
You don't know? I posted so many times, I thought everybody on earth knew
I live on a river. Last storm Irene, and a mismanaged resovior destroyed my car. Flooded/totaled then went to an insurance auction. The car treated me so well, you know, hugs, kisses, breakfast in bed. I had to get it back, so I bought it before the auction, then took a long time to rewire it. My second time at the track, was the Inf./Niss. shootout at Atco. Of course I won it Well my class Thanks for caring
Old Oct 29, 2012 | 04:46 PM
  #3060
denchan350gt
I got in 14 runs between 9 and 1030 on friday night after changing my mind for going to capitol. My friends only got in 2 runs from 6-1030.
The fastest I got the car was 13.4@106 friday found out Sat I had a fouled spark plug in cyl 2.
Changing all spark plugs after this storm passes car should be faster hopefully after the spark plug change. Funny thing is the car never showed a CEL just hesitated after launch then takes off. I found out through cipher that I had codes.
Come out friday night if you can.
