Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Sep 22, 2007 | 10:59 AM
  #801
Alberto's Avatar
Alberto
Cranky FI Owner
forcefed-how much boost for 600whp? Pump gas?
Old Sep 22, 2007 | 11:25 AM
  #802
ForcefedZ's Avatar
ForcefedZ
Originally Posted by eagletanggreen
Once again great run... It only get better (times) would love to see you hit a nice 60ft. Ever considerd 3.3 FD to keep it in 4th in the traps.
Would you mind posting your dyno sheet, I would love to see your power cruve. 132mph trap is fast.
Here's the latest dyno chart. Boost pressure is being measured at the intercooler inlet, my AEM data logs were showing about 20-21 psi at the intake manifold. This was a mix of 50/50 mix of 93 octane and race gas.
I have the stock rear which I'm assuming is the 3.5:1 ratio. I was trapping in 4th. I was running 26/10.5/16 ET streets. You just need to bump your rev limiter up, the tires will grow in height by the end of the track.
Attached Thumbnails Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )-350zdyno.jpg
Old Sep 22, 2007 | 11:28 AM
  #803
Alberto's Avatar
Alberto
Cranky FI Owner
DAMN! How are you able to keep hp from dropping off up to 7500rpm's? What lower/upper plenum/mods do you run for that? With 7500rpms to play with I see why you can stay in 4th with a 26" tire...
LUIE-your snails would LOVE a tune like that!
Old Sep 22, 2007 | 11:52 AM
  #804
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
+1
Thats sick you can keep power from falling after 7k. Very impressed!
Are these upgraded Greddy Turbos? Cuz they spool up like my GT30's, not like a regular greddy turbo?
Old Sep 22, 2007 | 12:07 PM
  #805
ForcefedZ's Avatar
ForcefedZ
My upper and lower intake manifolds are completely stock. Tuning can make all the difference, regardless of the engine/turbo package.
Old Sep 22, 2007 | 12:09 PM
  #806
ajcool2's Avatar
ajcool2
WOW just WOW...
Old Sep 22, 2007 | 12:12 PM
  #807
ForcefedZ's Avatar
ForcefedZ
+1
Stock Greddy 18g turbos. During that run the variable cam timing was disabled which impacts the lower rev range response and power. My car makes the same peak torque as it's peak HP figures with the cam timing control functioning correctly.
Old Sep 22, 2007 | 12:20 PM
  #808
Alberto's Avatar
Alberto
Cranky FI Owner
With race gas you can obviously run more timing to make more power and help the curve from falling, but I have NEVER seen a curve stay flat past 7000rpm's on these forums. Got to be more to it (the tuning)!
edit-any head work? What cams/valvetrain?
Old Sep 22, 2007 | 12:25 PM
  #809
eagletanggreen
Got Track!!!!!
So you disabled variable cam timing, for what reason? Was it to get a more lenier power curve, or was it not working right?
You really have my attention! I have everyones dyno sheet and I have never seen power all the way up top like this before.
Old Sep 22, 2007 | 12:35 PM
  #810
ForcefedZ's Avatar
ForcefedZ
The heads are stock except for the cams I just installed (BC stg2) stock springs and retainers. Maybe it's because I have Dyno-Jet :-D joking...
Old Sep 22, 2007 | 12:38 PM
  #811
Alberto's Avatar
Alberto
Cranky FI Owner
Hey man, veryi mpressive power curve, Id love to see a datalog of A/F and timing...I'll look into the specs of those cams.
Alberto<----thinks of what he'd do with a curve or rev limit as high as that down the 1/4
Old Sep 22, 2007 | 12:43 PM
  #812
ForcefedZ's Avatar
ForcefedZ
I have some O2 sensor trouble codes that come on. When they come on the factory ECU will disable the cam timing which default to full retard, hence the missing 50-60ftlbs of torque of the dyno graph I posted.
I have a Haltech Platinum sitting here (thanks Injected Performance) that I wanted to test out for this event but I just ran out of time. I am pretty excited about the unit. Complete cam timing control, which can yield some serious torque. I'll be testing the unit sometime this week.
Old Sep 22, 2007 | 12:45 PM
  #813
eagletanggreen
Got Track!!!!!
Please keep us updated... I am looking into switching to the Haltech myself..
Old Sep 22, 2007 | 12:49 PM
  #814
ForcefedZ's Avatar
ForcefedZ
The AFR's are on plotted on the dyno graph. Ignition timing is dependent on too many variables (fuel burn rate, compression, air and water temps, etc.) to just directly compare.
Old Sep 22, 2007 | 02:54 PM
  #815
ACEMAN's Avatar
ACEMAN
Master
Thumbs up Updated The List With Everyones Times!!!
The ones updated were...
1. My time
2. TyWinters Bolt on time
3. Jouvert00's Vortech time
4. Seb-Specialty-Z's 07 bolt on time
5. ForceFedZ' TT time
Thanks Guys,
And keep the times coming
Later
Todd
Old Sep 22, 2007 | 06:07 PM
  #816
Audible Mayhem's Avatar
Audible Mayhem
My350z
the reason the graph is going so straight is because the boost level is climbing at the top of the rpms.
very nice trap though!!
Old Sep 22, 2007 | 10:46 PM
  #817
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Great times, guys.
Todd, glad to see you finally get ahead of me. Congrats on that. Due to certain unforseen circumstances, I don't think I'll be beating my (and your) time for a while. I'll be back though. Just watch out.
Old Sep 23, 2007 | 11:08 AM
  #818
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Great times, guys.
Thanks Chris,
I hope everything is ok... Look forward to seeing more times from you.
I will keep my eyes wide open
Todd
Old Sep 23, 2007 | 11:28 AM
  #819
Alberto's Avatar
Alberto
Cranky FI Owner
Todd-here is a pic of my slip, please update
Old Sep 23, 2007 | 11:55 AM
  #820
ACEMAN's Avatar
ACEMAN
Master
Thumbs up Updated With Alberto's Tt Time
Congrats Bert,
Thats a very nice time. Cant wait to see what you do with high boost.
Todd
