Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Oct 27, 2011 | 07:00 PM
  #2801
08NismoZ's Avatar
08NismoZ
Ahhhh yeaaaa back on the top 25! Thanks!
Old Oct 27, 2011 | 07:44 PM
  #2802
Thumbs up
Originally Posted by NightShade
Here are the times I ran last Friday. #1975
I think I still have a little more time left in this setup if I'm reading the slips correctly. On the 13.39 run I think I launched right but messed up shifting somewhere. On the 13.46 run I think I launched OK but shifted better, especially since I had a trap speed 1mph higher correct?
Also, I'm hitting the 8k rev limit in third a couple hundread feet before the 1/4 mile. It's driving me nuts cause the car just starts to decel, or I have to shift. Both of which screw up my time. I guess I won't fix that till I get new gears though.
After about 7pm it started getting crowded and they kept spraying water all over the place. I couldn't get under a 2.1 60' after that.
Almost forgot:
2008 base
intake, hfc's, cobb canned tune stage 1, street tires.
Impressive driving for all-motor 350Z. Congratulations.
Old Nov 7, 2011 | 04:06 PM
  #2803
ajcool2's Avatar
ajcool2
I ran my fastest time on street tires this weekend with a 12.3@109 with a 1.81 60'. Im not sure why the trap is so low. I'm positive I could have pulled a 1.7 if I would have sprayed just a little bit sooner. My 19's were hooking right up all weekend. It's nice to finally know how fast I am in full street trim. I'll be going all out on the 19th taking my seat out, installing the light weight battery and putting the slicks on.
Old Nov 10, 2011 | 02:53 PM
  #2804
2bad240's Avatar
2bad240
got my cage in tonight. thinking of running it tomorrow night
Old Nov 12, 2011 | 04:20 AM
  #2805
denchan350gt's Avatar
denchan350gt
Nice!! Good luck if you go.
Old Nov 12, 2011 | 12:00 PM
  #2806
2bad240's Avatar
2bad240
Ran a new best
Then this happened.
Old Nov 12, 2011 | 12:43 PM
  #2807
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Congrats on the new PB but @ the aftermath.
Old Nov 12, 2011 | 12:52 PM
  #2808
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Another Kinetix plenum failure... Not surprised, but sucks to see. Congrats on your new best time.
Old Nov 12, 2011 | 01:13 PM
  #2809
3hree5ive0ero
Retired Admin
^ +1 Kinetix is known to fail more often than any other plenums out there. Hopefully, it's just the plenum and no other parts and none of the pieces got into the engine.
Old Nov 12, 2011 | 01:26 PM
  #2810
2bad240's Avatar
2bad240
Its the second one I have broke in the past 4 months. The first just cracked. This one blew up. I could care less about the plenum. I'm just upset it destroyed my hood
Old Nov 12, 2011 | 01:35 PM
  #2811
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I'd just go with a spacer or APS Tallboy instead to add volume to the OEM manifold. The Kinetix + boost and/or nitrous often = FAIL
Old Nov 12, 2011 | 02:24 PM
  #2812
2bad240's Avatar
2bad240
I'm gonna build one.
Old Nov 12, 2011 | 02:25 PM
  #2813
Ran a new best
Then this happened.
Sorry about the damage. Not the first I have seen with the plastic Kinetix upper plenum and nitrous. But I have not seen the front engine cover destroyed.
Old Nov 12, 2011 | 02:34 PM
  #2814
3hree5ive0ero
Retired Admin
I'm guessing that happened because of a lack of tune, stock timing, running slightly lean, 150 shot, and probably on regular 93 octane. All that = detonation. You're lucky the weak Kinetix is what gave up before something worse happened. Maybe you should start thinking about taking care of some of that.
Old Nov 12, 2011 | 03:34 PM
  #2815
IfastR's Avatar
IfastR
2008 350z base stock 6sp
aftermarket wheels (stern super heavies lol) and nexen street tires
I know, I know but the wheels came on the car and I'm trying to find stockers
[IMG][/IMG]
Old Nov 12, 2011 | 04:00 PM
  #2816
2bad240's Avatar
2bad240
No I have had it on the dyno several times a/f is fine and I have a wideband in the car. With my 2 stage nitrous setup I'm having flow issues and getting to much fuel and it backfired in the plenum. I have to change my setup. To get equal flow.
Old Nov 12, 2011 | 05:08 PM
  #2817
- bigc -'s Avatar
- bigc -
yet another racer, a real racer, blowing the welds on his intake...
Old Nov 13, 2011 | 06:24 AM
  #2818
2bad240's Avatar
2bad240
lol no welds on that intake. but im gonna do change my setup over the winter so i wont have this issue anymore
Old Nov 14, 2011 | 02:06 PM
  #2819
ajcool2's Avatar
ajcool2
Pics of hood?
Old Nov 15, 2011 | 04:28 PM
  #2820
2bad240's Avatar
2bad240
