Drag NHRA, IDRC, IHRA, NDRA
Can I use these drags??
Old Sep 15, 2007 | 07:13 AM
Gooey's Avatar
Gooey
Default Can I use these drags??
I have a salvage yard and came up with a brand new set of wheels and bgf drag radials on. I dont know if it will fit. The tires are 275/50/15 the wheels are same bolt pattern but the offset looks crazy. It looks liek one of those weld 5 star wheels but the backspacing is reallll close. theres like a 6-8in lip on this wheel.
Think I can fit these on the Z>
Old Sep 15, 2007 | 07:14 AM
Gooey's Avatar
Gooey
or at least use 15" wheels maybe I can just transfer over the drag radials to a new wheel
Old Sep 15, 2007 | 07:29 AM
Julian@MRC's Avatar
Julian@MRC
15x8 with 5.5 back space weld will fit NON brembo cars
Old Sep 15, 2007 | 07:42 AM
Gooey's Avatar
Gooey
if I take some pics of it you think you can tell me if it will fit? I have non brembo so hopefully I can take these to the track event
Old Sep 15, 2007 | 07:45 AM
Julian@MRC's Avatar
Julian@MRC
there is a formula for fitting the Back Spacing on line some where..Basically, measure the BS on your oem rim and do it to these and see if its close.
Old Sep 15, 2007 | 08:04 AM
Gooey's Avatar
Gooey
this is the front of the wheel
and the back
Old Sep 15, 2007 | 08:14 AM
04treefiddy's Avatar
04treefiddy
i think you will need spacers on the back and either some longer studs or new lug nuts to fit them.
Old Sep 15, 2007 | 08:16 AM
Gooey's Avatar
Gooey
the rears are very close to the lip the rears will fit that no problem im just afraid the fronts will stick out way too much and damage my quarter panel
I guess only way to find out is by tryin
Old Sep 15, 2007 | 09:20 AM
coachk's Avatar
coachk
I have a set of the Weld ProStars 15x10 and the outer lip is 3".The inner lip is almost 7".Mine have 5.5 rear spacing and work fine with the proper lugnuts.
Old Sep 15, 2007 | 09:23 AM
coachk's Avatar
coachk
IMHO those are going to look like $hit on the front and not good for drag racing.Be very careful when you put them on and make sure you have the right lugnuts.
Old Sep 15, 2007 | 10:29 AM
ajcool2's Avatar
ajcool2
Your so lucky Jon. Why cant I just find some drag radials. lol
Old Sep 17, 2007 | 06:34 PM
Gooey's Avatar
Gooey
http://www.discounttiredirect.com/di...=10&bp=5-114.3
i just purchased thesewheels. Hoping toput the DR's on them. Think it will fit the Z?
15x10 38 offset
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
praxis
Feb 15, 2005 04:51 AM
